Topic Title: any cooker experts
Topic Summary: Faulty element
Created On: 20 March 2013 09:26 PM
beaver74
Hi Guy
called to a oven tripping out the RCD.fault to earth found,got replacement element and installed.run up for about 4 mins then triped out the rcd.retested the new elemnt once it cooled down and down to earth.
got a replacement from the same place and this time before I go back , I have rigged it up at home,runed up again for about 5 mins glowed well and again triped.
it seems to have split slightly and again is now down to earth.
element is 1000W.
question is surely 2 in a row on on site and on straight of a plug top is a long shot to be bad luck.
any ideas
 20 March 2013 09:39 PM
What sort of oven? If it is a fan oven, then it maybe designed to have the fan blowing on it when on. I had a "Friday afternoon" oven delivered new - a good make, but the fan and element connections were reversed. When the oven reached temperature, it switched off the fan - it should have left the fan on, and switched off the element!
 20 March 2013 09:43 PM
beaver74
it is a bulk standard diplimate conventional oven the element in question is the Base element.
 20 March 2013 09:45 PM
beaver74
it run up loverly with 240V straight on it. after about 4 mins i tuned it off to cool when I tried it again it started to trip
 20 March 2013 10:00 PM
I suppose the elements are 240 volt ones? !
 20 March 2013 10:03 PM
beaver74
yes stamped 240
 20 March 2013 10:46 PM
M.Joshi
Are the replacement elements manufacturer original parts or pattern/clone ones?
The element may have cracked as it is not designed to be on continuously without thermostatic control and fan cooling.
 20 March 2013 10:59 PM
beaver74
there is no fan cooling as it is the base element
 20 March 2013 11:26 PM
beaver74
now to my way of thinking the element should be able to runn 5 min to get up to temperate with out problem.this is a base element.
 21 March 2013 02:03 AM
potential
I'd buy another manufacturer's element from a different source.
It is possible that you have a bad batch or that they have become damp.
 21 March 2013 07:17 AM
SherlockOhms
Common Mode Failiure
 21 March 2013 10:01 AM
beaver74
this new base element glowed nice.I take it the base element should glow like all other elements.
