Topic Title: Shower route
Created On: 03 March 2013 05:13 PM
Avatar for frspikeyhead.
frspikeyhead
I have a rather strange domestic layout whereby I will have to route at least 10 metres externally from CU to shower. I am trying to avoid using swa if I can but........ Any suggestions?
 03 March 2013 05:18 PM
PVC conduit?
 03 March 2013 05:40 PM
SamP
Plastic conduit would get my vote also. 10mm t and e should fit 25mm from memory.
 03 March 2013 06:41 PM
aligarjon
I think SWA would look better long term, conduit tends to fade or discolour in quite a short period of time.
Gary
You could terminate the swa externally in an end box if you are struggling for space inside and just extend the internal cores on through without cutting them.( no joint)
Edited: 03 March 2013 at 08:51 PM by aligarjon
 03 March 2013 08:34 PM
Avatar for jsa986.
jsa986
Got to be conduit if you dont want to use SWA , and Singles,. T&E will be no fun to try an pull through if you have a bend in the run!
Or galv trunking would be another option
www.icertifi.co.uk
BS 7671 electrical certificates on your iPhone/iPod
www.tapengines.com
Electrical apps for electricians and engineers on iPhone & iPad
 03 March 2013 09:29 PM
mikejumper
Unless it's a fairly straight run, I'd bite the bullet and use SWA.
You could fit a couple of terminal boxes each end at the point of entry to the house and continue inside from the CU and to the shower with T&E.
 03 March 2013 09:40 PM
Avatar for Rulland.
Rulland
I agree with Mike, 10mm is a pain at the best of times, let alone getting it round conduit, why haven't they devised some sort of 'tri rated' cable type PVC that eases the grief in pull cords and the like?.
 03 March 2013 10:05 PM
SamP
I'd imagined the run to be straight out and straight up, as I've done before. Anything different to this, I'd take the SWA option. Definitely less sweary.
 04 March 2013 06:45 PM
frspikeyhead
Unfortunately there are a couple of bends so I don't think conduit is an option. Does anybody make 3 core 10mm suitable for exterior or am I just going to have to bite the bullet.
 04 March 2013 08:47 PM
statter
..... how about pyro, installation is a test but once it weathers the bare copper is often lost against brickwork.
 04 March 2013 09:00 PM
mossep
Could get some 10mm 3c nyy-j, might be a bit dear though.
 05 March 2013 06:32 AM
Thripster
What would be wrong with conduit and 10mm singles?
