Topic Title: Double pole rcd Topic Summary: Created On: 22 February 2013 11:52 AM Status: Post and Reply |
Can anyone remind me in what situations double pole (as opposed to single pole) rcd protection must be used (caravans come to mind)?
Regards Edited: 22 February 2013 at 01:50 PM by geov |
Caravans is one, caravan sites is another, and marinas too.
Then there are situations where the N needs to be disconnected - e.g. if an RCD is used as the main switch on a domestic single phase installation. Where the RCD is downstream of another RCD and it's required to have discrimination between the two in the case of N-E faults. Where local generation can operate in parallel with the mains (e.g. a PV inverter) and the circuit the generator is connected to also supplies current consuming equipment. probably a few others too... - Andy. |
Thanks Andy, was having a bit of a "blonde" moment!
Double pole rcd
