Topic Title: Issues with Overhead Electric Traveling Crane
Created On: 19 February 2013 09:00 PM
rcs2
Hi,
We've got a few issues with one of our Overhead Cranes. Basically, when in operation the crane is constantly tripping on O/L current when raising with a load attached. The load is around 60t. However, this only happens at the far end of travel and no other place within the facility. I believe it's due to a voltage drop occurring across the BusBar's as they're around 100m long and 'fed' from the end furthest from the problem. We've taken current readings across all 3 phases (415Vac) and they are (reasonably) balanced across the full travel with load attached. Could the distance of run increase the reactive power and cause the tripping. I'm assuming that an increase in reactive power won't show up on a standard clip-on ammeter. Also, I've noticed during testing that the further the crane moves along the busbar when it picks a load up the lights on the crane dim more the further in moves along but the current measured remains the same.
The FLC of the hoist motor is between 80 > 120A depending on lifting speed. It's a Slip-ring (rotor resist) 3-phase motor.
Any advice would be great.
Ray
 19 February 2013 10:56 PM
Jaymack
From the symptoms, I'd be looking for faulty connections on the busbars, particularly the downshop busbars. 100m is not too lengthy, I've had busbars about 1000m length in an aluminium smelter, but fed from both ends to counteract the voltage drop for 2 overhead cranes. (Fun and games with thermal expansion on the smelter startup). There is a distinct danger of hoist motors reversing due to "single phasing", i.e. a hoist load may fall with the load rather than raise it, unless single phase protection is fitted.
 19 February 2013 11:52 PM
Legh
If the problem is volt drop, although I suspect something more since it has worked up until now, you could move the feeder cables and connect them to the centre of the busbars rather than at the end.
But then it depends how the busbars are positioned to allow for the run of the track.....
Legh
de-avatared
 20 February 2013 07:24 AM
rcs2
Thanks for the response. Forgot to mention that the busbar is a, rather poor, sectional design with joints every 2/3 meters. Therefore, we've got upwards of 40 joints along the length with around 25% being outside with very little weather protection. Thats why i was wondering about voltdrop (across a bad joint) causing an increased current as the motor will be trying to lift the same load.
 20 February 2013 07:51 AM
Jaymack
There will be an increase in current for the "healthy" phases, which may result in motor overheating dependent on the load, but the power output will be less from the motor, under "single phasing" conditions.
No signs of sparking at busbar joints? Fault finding should be possible from the crane gantry, assuming the downshop leads are the problem; it could be shoes but is more probably the busbars. A low resistance ohmmeter, or preferably a Ductor tester could be used ......... initially at the suspect points. Finally, I would be looking at the frequency of maintenance checks, and the stocks of spares.
 20 February 2013 07:55 AM
Jaymack
 20 February 2013 10:45 AM
rcs2
Jaymack,
Thanks for the responses. We changed the shoes as an easy 'quick fix' but, apart form normal ware & tear, they were fine. Our plant operators (no technical training) have reported sparks but upon inspection there was very little evidence of sparking on either the shoes or bars. The system is around 6-7 years old and the maintenance is reasonable good.
Will keep digging.
 20 February 2013 12:11 PM
stateit
This is certainly nowhere within my realm of experience. But...
A thermal imaging camera would surely help in inspecting the busbar joints.
S George
http://www.sg-electrical.com
 20 February 2013 01:42 PM
Jaymack
Perhaps, but after the fault position, if the camera was following the crane shoes. No current flowing - no thermal image.
 20 February 2013 02:00 PM
Jaymack
These are shrouded bars no doubt (and expandable to boot, pardon the pun); in which case, sparking at high resistance connections may not be evident. The continuity requires to be tested across each suspect joint, and co-incidently by shaking the busbar. Alternatively 3 voltmeters connected across the incoming phases, but located and viewed on the crane or from below, should detect the phase/s and position of the faulty connection/s, as the crane travels.
 20 February 2013 05:58 PM
whjohnson
If it's rotor resistance, then are the resistances and their internal connections ok on each phase?
Is the crane remotely operated via a pendent (and timed relays switching out the resistance banks as the motor speed is increased?)
Or is there an human operator up in the cab 'driving' the thing?
I used to work on some very old Vaughn O/H cranes dating back to the 1940's with exposed round section trolley wires running the full length of the plant for the supplies, and brass shoe collectors (pick-ups) which fed the crane directly from the wires. The crane had to be 'driven' from the cab via controllers which were like the old tramcar controllers with a big handle on top.
Basically, if the operator wound the controller to full speed too quickly, the motor trip would operate (old Allen West dashpot set-up). No problem with the load because there was the biggest eff-off brake solenoid (3 starred coils lifting a massive laminated lever against a spring - they knew how to build em in them days!) which failed 'safe' with no supply.
Just wondering if the rotor resistances are being switched out too quickly, especially as there is a load weight hanging on the hook.
I'd also be checking to see if the hoist motor brake is working properly and not dragging too much at the far end of the run.
Whilst up there, get the fitters to check any drive shaft bearings and gearboxs too!
Edited: 20 February 2013 at 06:05 PM by whjohnson
 22 February 2013 10:45 AM
jcm256
rcs2: What does the Report of Thorough Examination; say about this fault, I am sure this fault would be on the report for further investigation or immediate repair.
The Lifting Operations and Lifting Equipment Regulations 1998 (LOLER) require the user to hold a current Report of Thorough Examination. This equipment requires thorough examination at least every 12 months
Just note: be careful around lifting equipment, no need to tell you that.
http://www.healthandsafetyatwo...ering/wilfred-williams
 24 February 2013 02:09 PM
rh2577
Too much speculation here for a very dangerous item of equipment (I should know I'm involved with crane maintenance and repair). Get a professional crane maintenance company in to check it out.
HTH
Rob Heywood MIET
As you get older, three things happen, the first is that your memory goes and..........I can't recall what the other two things are!
Norman Wisdom
 24 February 2013 05:09 PM
Jaymack
Having been a shift maintenance electrician for many years in the steel industry, the most probable cause of this fault is fairly obvious. An industrial maintenance electrician, requires broader technical knowledge than say one who is only exposed to house wiring.
Perhaps pertinent for smaller organisations with no skilled maintenance staff, but quite frankly, the interviewing techniques could be to blame, in that the correct calibre of personnel has not been selected.
I'm just a poor country boy trying to earn a crust!
