Topic Title: Loadstar rcbos
Topic Summary: Strange readings
Created On: 16 February 2013 06:46 PM
tillie
Hi , I installed two radial circuits for a kitchen in a commercial premises.
I have installed each circuit on its own B20 Loadmaster Rcbo.
Tested the Rcbos Today and came across a problem with one of the Rcbos.
On 1x test it tests fine , but on the 5x test on 180 degrees it kept giving me >40. It tests fine on 0 degrees 7.9ms.
It will only test fine if I actually disconnect the load at the Rcbo 18.3ms.
Now I know that the Rcbo should be tested with the load disconnected but I have never had to physically disconnect the outgoing load from the Rcbo before, I would just make sure that all loads were disconnected from the circuit.
Is the Rcbo good or should I replace it.
 16 February 2013 07:42 PM
If it tests ok off-load I wouldn't worry about it Tillie, that's the way we're told to do it!
