Topic Title: Latching a door bell
Created On: 16 January 2013 01:45 PM
Avatar for Martynduerden.
Martynduerden
Hi folks
I have a problem with a doorbell, it works fine when the user presses and holds for about a second but if said user presses and releases quickly the action is not registered, I need to find a solution which latches the button momentarily or a button which is slow to release.
Added complication is the button needs to be decorative ie not standard doorbell button.....don't ask!
Cheers chaps and chapesses
Martyn.
 16 January 2013 01:54 PM
Avatar for OMS.
Latching relay and 0-6 second timer in a box by the TX ?
Is the circuit voltage "low" - often the cause of the bell not operating on "short" press.
Failure is always an option
 16 January 2013 01:59 PM
Sounds unusual that the bell doesn't start to ring immediately (or is there something more to it "registering"?) Might the push button be on its way out - a long press really just being a symptom of a hard press?
 16 January 2013 03:53 PM
Martynduerden
The doorbell is part of a security system, the button is a device on a zone and is set to NO the chime is a common function to several actions. I can make it work every time but I need to avoid an instruction leaflet on pressing a button!
There is no tx.
Martyn.
 16 January 2013 04:09 PM
The panel isn't set to double-knock or similar on that zone is it?
 16 January 2013 04:34 PM
Avatar for OMS.
LoL - not just a doorbell then Martyn
 16 January 2013 06:24 PM
Avatar for slittle.
If you can prove the button good, how about one of of these
http://www.tk-consultants.co.uk/TKT160.html
Found them in a google search for something a few days ago.
 16 January 2013 08:01 PM
Avatar for Legh.
Legh
@Stu,
That's a good link, all it needs is a RF front end with a small transmitter in the door press housing and the door bell can be positioned anywhere without the need of worrying about volt drop.
I'll look at their site in more detail at some point...
Legh
 16 January 2013 08:05 PM
Avatar for Rulland.
Rulland
If its on a zone then the panel should see it everytime!-maybe a slight delay, but should still do what it's progged to do, also some panels have the facilty to change the 'zone response time', ie the length of time a zone must be active before the panel reacts and treats it as a change of state (Tex premier panels for example).
 16 January 2013 10:21 PM
Martynduerden
Oh no it's a doorbell with bells on or without in this case !
Martyn.
 16 January 2013 10:24 PM
Martynduerden
No double knock suite is off for that zone, the button is good ( tested anew one today)
Martyn.
 16 January 2013 10:27 PM
Martynduerden
Client has done a U turn. Wireless standard bell going in tomorrow, £300.00 later it's a 20 quid solution!
Martyn.
 16 January 2013 10:28 PM
SKElectrical
It sounds like a job for a pin hammer. a little tap here a little tap there to misshape it?
You could consider applying a small blob of strawberry jam bi-annually
 16 January 2013 10:48 PM
Martynduerden
That's actually funny, why do I suspect your serious ! Lmao
Martyn.
 16 January 2013 11:22 PM
SKElectrical
What surprises me about these wireless doorbells is:
i) how ugly and bulky the push buttons are
ii) you cant hard wire the bell - you are forced to use batteries.
These two factors make it no good for my richer clients who
i) want it to look half decent
ii) don't want to be up ladders changing batteries
 16 January 2013 11:31 PM
Martynduerden
Modern push buttons use Mili watts in power consumption and tend to be solid state (10 year life) as for size and design the one I collected today looks identical to a standard door bell button.
I'm not going to be short of available permanent 12v supplies trust me!
Martyn.
 17 January 2013 12:06 AM
SKElectrical
How do you wire something that only accepts batteries
 17 January 2013 12:09 AM
Martynduerden
Carefully
Martyn.
