Topic Title: Vertically hung fluorescent tubes
Created On: 13 January 2013 10:57 PM
Avatar for sparkingchip.
I was in the Krispy Kreme doughnut shop with Selfridges, Birmingham this afternoon enjoying a coffee with of course a doughnut, butterscotch flavour to be precise.
Just over from where we were sat there is a area of the store lit by fluorescents. There is a wire mesh tray at high level with the control gear sets and wiring mounted on it all sprayed matt black. Suspended from this there are a large number of fluorescent tubes of varying lengths randomly spaced and at differing heights all hanging vertically to give the impression of not being mounted in a fitting thus just a bare tube.
In reality there is a small fitting onto of the tube connecting it to the hanging flex, then from this a small cable runs down the side of a plastic tube that contains the fluorescent lamp to another fitting on the bottom of the tube.
Any idea where these can be sourced?
Also having tried Googling them I have seen suggestions that if hung vertically the gas in the fluorescent tube will settle and the tube needs flipping over occasionally to maintain performance. Incidentally I have also seen suggestions that vertical tubes are particularly good for some kinds of indoor horticulture!
Andy
 13 January 2013 11:07 PM
peteTLM
i had the 'pleasure' of having to dismantle a few of this system in an architects office, but these were mounted horizontally. I did see what make they were and googled it and had a look at there website, but can i remember what make they were? No.
They have a very thin plastic jacket around the glass, presumambly to contain it in the event of a crunch.
 13 January 2013 11:14 PM
Avatar for leckie.
Do you meant the cover? Encapsulite?
">http://www.encapsulite.co.uk/index.php
I've used these when you can't have a lamp breaking and contaminating food production etc. if that's what you mean.
I didn't know vertical lamps were good for the those special greenhouses though.
 13 January 2013 11:20 PM
peteTLM
yes.... my ones were the stick light
 13 January 2013 11:29 PM
 14 January 2013 10:48 AM
northernlights
Have a look at www.kinoflo.com.
These lights are used extensively in the film industry and can be used with the conrol gear remote to the fitting
 14 January 2013 02:39 PM
I heard of tungsten-halogen needing to be horizontal (as they work by re-condensing the evaporated metal back onto the filament), but not of similar problems with fluorescents - if there was such a problem I would have thought that wall lights with circular or 2D lamps would have been in trouble...
