Topic Title: Compact RCBO
Topic Summary: douple pole
Created On: 07 January 2013 09:30 PM
DOUGIE1000
looking for 16amp of 20amp double pole RCBO the same size of 1 modual MCB.
any out there making breaking on double pole after a fault? its to bastertise an electric boiler feeding each of the 3kw elements.
Dougie
Power Plus Electrical.co.uk
 07 January 2013 09:56 PM
SKElectrical
sorry dougie, what are you asking?
 07 January 2013 09:58 PM
DOUGIE1000
looking for a make on compact rcbo 2 pole, looked at GE and proteus but none are double pole............anyone know of such rcbo?
Dougie
 07 January 2013 10:10 PM
Avatar for leckie.
I thought ge did do a 1 module dp rcbo?
 07 January 2013 10:14 PM
DOUGIE1000
http://www.gepowercontrols.com...cat_EN_UK_ed10-10.pdf
page b15, says neutral is unswitched on all compact rcbos,
Dougie
Avatar for leckie.
 07 January 2013 10:16 PM
DOUGIE1000
i would rather something from UK can find plenty from auistralia (they must use a lot or http://www.aliexpress.com/stor.../901254_550501494.html
Dougie
 07 January 2013 10:18 PM
DOUGIE1000
http://www.doepke.co.uk/rcbos/rcbos.HTML
Or this make?
says again neutral is "solid neutral"
Dougie
 07 January 2013 10:35 PM
Avatar for leckie.
Can't you fit an enclosure with a double module rcbo, hager or something?
 07 January 2013 10:40 PM
DOUGIE1000
Yes normally however this is replacing MCB's on an electric boiler that has 16amp chint MCB's the control enclosure for each element . the chint mcb is mounted on the side of the boiler in a plastic enclosure and has the connections tight pressed against other components inside control center and hence the no room problem.
im wanting the rcbo 2pole as an 3kw electric element failure will isolate element and mean boiler can still run however one element down and not needing me to go fix a n-e element fault.
Dougie
 07 January 2013 10:45 PM
SKElectrical
Hi dougie drop me an email and I will forward you an email from my local ex napit inspector who now supplies compact rcbos. he does not have a web page but he is reputable.
sipoole@ymail.com
 07 January 2013 10:50 PM
DOUGIE1000
sipoole@ymail.com
done
Dougie
 07 January 2013 11:04 PM
SKElectrical
I just don't get my phone, I really don't - I think I have emailed you. you should have 2 attachments, one being a pricelist. hi s number is at the bottom of the page.
 07 January 2013 11:05 PM
Avatar for sparkiemike.
sparkiemike
These guys sell double pole RCBOs for their caravan hook ups.
The are compact and double pole
I have purchased the RCBO separately before
You want their HR4 series, which are not on their website, give them a ring and they should be able to sell you some.
http://www.raytechinternational.com/caravan_hook_up
 08 January 2013 10:48 AM
Or these (top half of the page) - I can confirm that the one I got was indeed DP switching - http://www.meteorelectrical.co...le-rcbo-s-type-b.html
 08 January 2013 08:15 PM
ady1
Quite popular in France, Hager, Mollier x pole etc.
Generally when the L&N terminals are in-line (side by side) as you look at them, they are double pole switching.
Ady
Resistance is futile.
 08 January 2013 09:30 PM
DOUGIE1000
Or these (top half of the page) - I can confirm that the one I got was indeed DP switching - http://www.meteorelectrical.co...o-s-type-b.html
Spot on, many thanks, great work guys!!.,!
Dougie
 11 January 2013 11:13 AM
Avatar for BigRed.
BigRed
Try Legrand, they are pretty good for this kind of thing to.
