Topic Title: recessed modular lighting
Topic Summary: what s the name
Created On: 28 December 2012 08:10 PM
123sparks
hi ya im new here.i have a job to replace an office lighting 600/600 and 1200/600 recessed modular light fittings but it is not on a conventional tbar system.the fittings fitting under the grid not on the grid and the fittings need to have a wing type in each corner of the fitting that when opened poke out and sit on a grid type.you then screw up the screw which pulls down on the grid and lifts the fitting up into the cieling to sit flush under the the cieling tiles.what i need to know is what is the name of these type of fittings as im having trouble trying to locate them.
all contructive input would be gratefully excepted
regards martin
 29 December 2012 02:25 AM
johno12345
it soudns like you are describing a fire rated ceiling and the lights to suit, would that make sense?
 29 December 2012 09:20 AM
eclipse
A photo would be good! I've used something similar in the past made by Siteco, very expensive though!
Now what was that reg no?
 29 December 2012 11:16 PM
Do you mean something like these things: http://uk.rs-online.com/web/p/...clips-hangers/0277547/ ?
 30 December 2012 03:16 PM
peteTLM
Hi Martin,
is this a conventional T bar type ceiling, or something fabricated out of plasterboard and metal grid?
Would a normal drop in fitting work? as the type you describe isnt very common.
 30 December 2012 11:16 PM
tyler1
Hi Martin
Are these the sort of fixings you are talking about?
Link removed/lum...-brackets-4-pack.html
Link removed/catalogue...d-recessed-luminaires
 30 December 2012 11:18 PM
tyler1
Hi Martin
My links were removed.
Lumafix brackets
Tamlite recessed fittings by C.E.F
