Topic Title: Mixing Bands
Created On: 17 December 2012 09:11 PM
MrOther
I know nout about tele-communications as a general rule, so any addition insight is a bonus.
I have an old Telephone socket, plastic clad and surface mounted. Intend to convert to a nice new flush fitting. Cable to put into wall horizontally a long safe zone. Next to it I'm gonna intsall a new socket. Metal clad. Hoping to get an all in one.
If memories serves when mixing Band I & II new Regs stipulate this is okay as long as the cables can withstand the highest nominal voltage, i.e. the telephone cable will have to withstand 230v -- which I think is a nonstarter.
If this is the case, if I serperate the pair into seperate back boxes with a metal interconnecting clip - just to make it easier to mount and to make sure they are parallel, would this still be a problem? Only under fault conditions methings.
Thanks again.
 17 December 2012 10:19 PM
Legh
I wouldn't want to mix Sparks with ACDC somehow
On the other hand you could bury a plastic backing box in the wall and keep them completely separate...
But then you'd have your work cut out making it look respectable.
Legh
de-avatared
 18 December 2012 06:46 AM
normcall
Start with worrying about all the hum and noise that might be introduced and you should be on the right track.
In my conservatory, I wanted a socket, a telephone point and network outlet.
Two single boxes mounted as you suggest, with one of those 'link clips' to get them spaced correctly.
power to socket and I used a combined telephone and network outlet (you could use a 2 unit grid , one for telephone and other for network).
Seems to work OK without any noise.
Norman
 18 December 2012 07:40 PM
MrOther
Norm I am just reusing the cable that is there -- little white multi-core thing.
As you described, the telepone is in a seperate backbox to the power but obviously are linked by cpc on the metal back box link. Is there any issues with this re: regs.
As I said, my concern is under fault conditions the telephone cable will not be suitable under fault conditions.
Sorry, if this seems pedantic, but I don't want to do my Ma's room up and muck about without offering her better then what she had.
She does the cooking, after all.
 18 December 2012 08:00 PM
MrOther
Similarily I'm also installing a socket and plug with a back box clipping them together.
EDIT: Reg 528.1 doesn't seem to address my concerns but I guess if it allows for both Bands to be on the same metal tray physically seperated then it should be okay because one would presume that the tray would be earthed.
Edited: 18 December 2012 at 08:30 PM by MrOther
 18 December 2012 10:14 PM
Legh
I think the BT lines are FELV so at some point there is a common earthing point. (50V dropping to 38V when the line goes hot)
I can't speak for the BT insulation though. It doesn't look that resistant.
Legh
de-avatared
 19 December 2012 07:34 PM
MrOther
That's Legh.
I think for the sake of "noise" I'll keep the Ariel and Telephone cabels away from mains.
One more question:how can you tell if a telephone socket is a seondary or master?
 19 December 2012 07:40 PM
Legh
The master will have a resistor and capacitor connected across the lines (filtering)
Secondary outlets are just paralleled up.
Legh
de-avatared
 20 December 2012 12:32 AM
MrOther
Legh
Your a gentleman, thanks.
 20 December 2012 10:48 AM
The capacitor is actually to generate the ringing signal (blocks d.c.) rather than as a noise filter and the resistor is there so that the exchange can tell the difference between nothing being plugged in and the line being broken (out of service resistor).
The reason the ringing capacitor is in the master socket, rather than in individual phones, dates back to the old rotary dials - which generated pulses. The pulses are of course a kind of brief a.c. so got through the ringing capacitor and causes the bells to "tinkle" when dialling out. To stop this the dials had a contact which shorted out the bells when the dial was anywhere other than its resting position. Once you could plug several phones into the same line, for the shorting out to be effective they had to share a single common ringing line (pin 3 I think) and so one capacitor.
