Topic Title: Contactor
Created On: 08 December 2012 10:49 PM
Westonelectrical
Can someone tell in (simple terms) how a contactor works and why you would use it?
 08 December 2012 10:52 PM
DOUGIE1000
Switch wire to coil to switch on larger loads ie motors
Dougie
Power Plus Electrical.co.uk
 08 December 2012 10:56 PM
Westonelectrical
Just wondering how it would work on a lighting circuit
 08 December 2012 11:13 PM
DOUGIE1000
A good example is a job we did few weeks ago, rows of contractors all in a lockable box, one 1.5mm ran to one light switch at this shop front door, the one switch put supply onto all the contractors coils and brought them on switching on all the lighting circuits for the store lighting.
Dougie
 08 December 2012 11:43 PM
Westonelectrical
What was so beneficial about it?.
 08 December 2012 11:46 PM
DOUGIE1000
Switching higher amp loads, or several contacts at once
Dougie
 09 December 2012 12:09 AM
hifly
it's a relay like you have on your starter motor in a car or van.
it alows you to switch a high load (lots of amps) with a normal switch (few amps)
Vince
 09 December 2012 04:07 AM
Martynduerden
I often use them to control full DB's essentially it provides the ability to switch on a large 3 ph board or a series of them with a light switch.
Tesco stores for example can be shut down with two key switches deepening on the requirement all done via several contractors.
Martyn.
 09 December 2012 04:31 AM
Another example is using a single phase circuit to control a 3 phase circuit.
Or an extra low voltage circuit to control a low voltage circuit.
 09 December 2012 08:24 AM
Rulland
I'd sometimes like to lock fellow contractors in a box too Dougie!.
 09 December 2012 10:07 AM
Westonelectrical
For example? A photo cell will switch the contactor on to allow the power to the light??. Is that right?
 09 December 2012 11:47 AM
impvan
Think of it as an 'electric crowbar'. You can switch a lot of power with a very small signal.
 09 December 2012 12:06 PM
DOUGIE1000
For once the spell check was spot on
Dougie
 09 December 2012 12:23 PM
DOUGIE1000
Spot on, photocell to switch on large lighting loads.
Dougie
 09 December 2012 12:42 PM
Westonelectrical
Nice one could it switch for not so large lighting load
 09 December 2012 12:46 PM
Legh
I have used them in conjunction with remote wireless key fobs. You lay in bed and with the press of a button all your garden lights come on. Press another button and your lake fountains and water features spring to life.
The wireless HF switch is connected to a control box which then activates the coil circuit of your contactor/s which then energizes lighting, power, pumps, DBs. The HF remote input has relatively little current passing through the system which is used to switch on heavy loads or just about anything you like.
Legh
de-avatared
 09 December 2012 02:02 PM
DOUGIE1000
West one,
Contractors come as small as 16amp 100amp, they even come mcb size and are great
We recently wired a house and had a contractor for all lighting and ring mains as woman was afraid of leaving the oven on or something when leaving.
We had a delegate board for radials for smokies, fridge freezer etc.
Dougie
 09 December 2012 02:07 PM
Still calling them contractors then Dougie!
 09 December 2012 02:24 PM
Legh
Yep, go into any hotel room operated by a card security system and plug in your card....and the power comes on..
Legh
de-avatared
 09 December 2012 02:30 PM
DOUGIE1000
Its this tablet, haha
Dougie
IET » Wiring and the regulations » Contactor
