Topic Title: 200amp TP&N Distribution Board
Created On: 06 December 2012 10:45 PM
davel81
200a TP&N Dist Board
Posted by Dave Lincoln on Dec 5, 2012 7:04
Hi
I have a customer having a new 3PH (TT) supply put into a farm / processing complex. - 4 seperate buildings + farm house. At present he has split phase, but is upping his production facilities. Western power are putting a cabinet in central to the buildings containing 4 x 100amp 3PH heads & 1 x 200amp 3PH head. I am currently fitting out the unit to be supplied by the 200A supply and am struggling to find a 2300 distibution board with a 200a 100ma RCCB kit. I usually get involved in domestic or 100a ph stuff!! Should I be looking for something different??
Dave
 06 December 2012 10:51 PM
peteTLM
Look at merlin gerin /schenider isobar 4. Every possible configuration available.
What protection is available for the submain between the supply position and the new unit that you are doing??
 06 December 2012 11:18 PM
Avatar for OMS.
I'll second that Pete - do you need an RCCB main switch - the protection will/should be back at the service position
MG Isobar 4 or NX compact with an add on earth leakage module in enclosure would give you isolation, OL and SC protection and the module will give you EF protection
Failure is always an option
 06 December 2012 11:21 PM
mawry
Thirded, can't go wrong with the schneider gear. if you need it they'll have it!
 07 December 2012 07:40 PM
jamieblatant
hager
Twitter: @rtindustria
 08 December 2012 04:15 PM
Avatar for slittle.
Merlin or Hager. Either works for me.
I've just installed a nice 400A merlin one that is adjustable for the RCD tripping parameters for a grain store.
 09 December 2012 07:17 PM
Avatar for Martynduerden.
Martynduerden
Look at the Merlin with the mgi2003 incomer kit as Oms said clip the add on module in for any level of protection Over / under voltage EF ETC ETC
FORTHED
Martyn.
