Topic Title: Destrat Fan Recomendations Topic Summary: Created On: 06 December 2012 03:08 PM Status: Post and Reply |
Looking to spec & install some destrat fans to improve the heating efficiency in a largeish warehouse I look after.
Have spec'd them up for size etc & I am looking at the following manufacturers: Ambirad Powrmatic Roberts Gordon Anyone got any other manufacturer recomendations or experience of the above? |
Powrmatic would be my choice - used them in some big MoD sheds recently and working well.
Ambirad are also good. as an alternative, take a look at Destratair units - they are mounted at low level and provide a large capacity recirculation that keeps the temperature gradient to within 1 or 2 degrees - part of (or used to be) Nuaire Group in addition, Puravent EliTurbo units are good quality and reliable. What's the heating system currently ? Regards OMS ------------------------- Failure is always an option |
What's the heating system currently ? High level gas fired warm air heaters (mix of Powrmatic & RG Combats) in the main warehouse areas which means the majority of the heat ends up in the roof & lower level is a lot colder so they are constanly on! |
OK - pretty normal stuff then, with the usual problem.
Depending on the height and the noise you can tolerate, I'd do a quick comparison between powrmatic and destratair as alternative aproaches (you could ask them for estimates/quotes - they both have good technical departments) and go from there in terms of advantages/disadvantages and present to your client - involve him in the process Regards OMS ------------------------- Failure is always an option |
Have looked at the Destratair website & quite like their lower level solution. Have sent them an equiry so will see what they come back with.
The client is the company I work for so I'm convinced it's worthwhile but I have to persuade the bean counters that it's cost effective! |
OK - as I said, do the advantages and disadvantages, including H&S and maintenance - see if you can calculate savings and thus payback
Good luck - don't use the phrase "The trouble with you, is you know the cost of everytning and the value of nothing" - not a good opening line I find Regards OMS ------------------------- Failure is always an option |
Have you looked at ZOO Fans? We have the ONLY 3rd party tested small Destrat fan on the market (no * no suprises). Please feel free to contact me directly with any questions: 720-428-2899. Link removed
