Topic Title: Kitchen power
Topic Summary: New outlets
Created On: 06 December 2012 07:50 AM
Fm
Looking for some advise.
A commercial,kitchen getting some new appliances all single phase and ss benches.
Existing power not in the correct positions,flush boxes.
Walls are clad with pvc sheet, stuch to reinforced concrete wall
3 options
Plastic conduit drops to surface boxes, do you get plastic hospital saddles?
White trunking to surface boxes
Or dado trunking
I like the dado option from a cleaning point of view,but havent seen it in a commercial kitchen before?
Anyone
 06 December 2012 08:14 AM
Avatar for Legh.
Legh
I think I'd prefer conduit drops, myself. However, I've never seen plastic hospital saddles before, come to think of it, neither distance saddles.
Dado trunking might not offer the amount of IP protection required in a commercial kitchen possibly due to warping. if run above places where excessive heat is produced..
Legh
 06 December 2012 08:47 AM
burn
Plastic is not suitable for the environment of a commercial kitchen. It will be very hot at times, particularly up near the ceiling.
Also, if the walls are clad with PVC or stainless steel panels this is usuallly for cleaning.
I have designed commercial kitchens with these and no surface wiring was permitted. Any conduit or trunking will gather dust and dirt allowing germs to breed.
It was a requirement of the local licencing authority, so I would check with them or the client if there are any such requirements here before you install anything.
burn
 06 December 2012 10:59 AM
Avatar for spinlondon.
spinlondon
I would expect either galv conduit or SS conduit depending upon the environmental conditions.
 06 December 2012 12:36 PM
Delbot321
In one of the recent commercial kitchens I worked on it was designed so they had allowed for periodic cleaning and washing down - all walls were plastic or stainless steel faced. All sockets were MK master seal with RCDs, machine isolators were minnimum IP55 either with PVC conduit or surface wiring SWA was used with waterproof glands.
The distribution boards were all located in stores area or non food areas.
Hope this helps
 06 December 2012 03:40 PM
Avatar for Legh.
Legh
I would agree with the statements made by other respondents but then, how many pub/hotel kitchens have I seen where plastic conduit has been used.?...,
The last one I quoted for ended up being rewired in plastic conduit by he brewery electricians !
Legh
 06 December 2012 04:10 PM
If it's too hot for PVC conduit, aren't the PVC singles in steel conduit equally dubious? (or doesn't it get that hot?)
 06 December 2012 04:38 PM
Fm
Sorry, its not near any heat from cookers, its where, microwave, soup urn and coffee machine is and a low level hot cupboard.
No issues near sinks etc
Current install is a mix of everything apart from dado
 06 December 2012 06:20 PM
Not hot enough to melt plastic conduit I would think! (nor plasic trunking or cable insulation for that matter)
 06 December 2012 08:04 PM
aligarjon
if there's plastic sheet on the wall i would think plastic conduit would be fine if not too close to direct heat sources.
Gary
