Topic Title: outside lighting
Topic Summary: anybody know a good system
Created On: 30 November 2012 03:05 PM
Ampman
Afternoon ,
Client would like 3 lights controlled from 2 pir detectors ,
so when 1 pir is activated all 3 lights come on + client would like a manual override switch .
Is there a cheapish way round this .
I would normally fit the GJD control box & run signel cables round to pirs etc.... to do this on this job would be well over the top
its a bungalow a small bungalow as well .
Please help
cheers
 30 November 2012 03:42 PM
I'd just wire ordinary (mains, relay switched) PIRs in parallel - one length of 3-core+E looping around the lot - pick out SL + N at the lights, L+SL+N at the PIRs, override-on switch connects L+SL.
 30 November 2012 08:36 PM
I'd go with Andy, just make sure the PIR's have relays not triacs as some don't like being paralleled.
 30 November 2012 08:46 PM
hifly
you could use wireless sensors and switch, possibly more expensive on parts but less on labour.
Vince
 30 November 2012 09:36 PM
Legh
Its not particularly difficult. Do as Andy suggests,
PIRs work Ok in parallel and the override switch is basically a single pole two way connecting the lights to the common, L1 connects the live feed looped to the PIR and L2 provides the switch line to the PIRs and onto the lights, the neutrals are there just to get into party......
Legh
de-avatared
 30 November 2012 09:44 PM
I've never found pir's that don't work in parallel, even cheap ones. What triac ones don't like is switching 2d's, etc.
If you use cheap Chinese triad pir's connect via a contactor.
 30 November 2012 09:46 PM
LoL - those triads will come after you with a big knife if you upset them -
 30 November 2012 09:48 PM
Legh
Chinese triad
Lol, How cheap do they get? must be from B&Q
Legh
de-avatared
 30 November 2012 09:49 PM
Oh sorry. An unintentional typo. Honest
