Topic Title: Trivial but annoying!
Topic Summary: Surface boxes
Created On: 20 November 2012 07:54 AM
SherlockOhms
Chaps,
Could anyone tell me why surface boxes are made of such a brittle material? Bone china is probably more resiliant!!
How many do you throw away after they crack whilst removing cutouts?
S.
 20 November 2012 08:58 AM
Avatar for hifly.
hifly
i use a rotory file in my drill makes a nice smooth hole and no cracking. can't same the same when i screw them to the wall.
Vince
Prove Dead Stay Alive
Christmas Cards for trades people
http://www.tradegreetingcards.com
 20 November 2012 09:01 AM
Avatar for vesuvius.
vesuvius
I think your referring to bakelite back boxes, commonly used where the likes of twin and earth cables would be entering the box through the notorious knockouts.
You can of course get more rigid plastic boxes probably like a thermoplastic. They have the 20mm knockouts for surface conduit instllations etc.
the only reason i can think of would be a costing issue, and its probably not a massive difference depending on where you buy your gear from. they are a pain in the back side though
 20 November 2012 09:09 AM
Avatar for Legh.
Legh
Nibble with pair of side cutters.and then a round file to clean up the rough edges.
Mind you there are different types of plastic. conduit = soft and T&E = hard.
Legh
 20 November 2012 10:42 AM
I used to cut the sides of the "knockout" with a junior hacksaw blade (the inner is bevelled, so the blade at 45 degrees just cuts the outer wall, not the base), snap off and then tidy up with a small file. It's time consuming, but you can get a nice snug fit around the cables.
 20 November 2012 08:14 PM
kaichung
Have you tried the rigid white UPVC boxes from MK or Marshall-Tufflex?
They are well made, stronger, and they work out cheaper over the long run, when wastage is accounted for (say one in three boxes).
 20 November 2012 08:33 PM
mikejumper
Probably to do with flammability and ease of moulding.
I agree though, they are brittle.
Judging that final turn of the screw to secure a surface box to the wall is alway a tense moment.
 20 November 2012 08:41 PM
Avatar for stateit.
stateit
That's a high rate of attrition there kaichung!
I like using the uPVC ones as well, but they don't visually match up with the urea formaldehyde accessories.
S George
http://www.state-it.com
 20 November 2012 10:53 PM
Avatar for Martynduerden.
Martynduerden
Ha a fellow box cutter,
I haven't broken an MK box to date - quickly touches so wood
Martyn.
 21 November 2012 10:07 AM
Avatar for OMS.
That's how I was taught to do it as an apprentice - although snapping them out with a 6" pliers and slapping the box on the wall with 2 x 1" No 8 woodscrews becomes the norm once you ventured out on site.
With T&E cable you used to saw out, clean up with a square file and round the corners with a rat tail file to match the T&E profile - the opening was always ever so slightly smaller than the cable to create a slight interference fit - not quite IP65, but close -
Not overtightning the fixing screws is the key - back in the days we used screwdrivers for slotted screws, you could "feel" the point when enough was enough - bashing them in with posidrives and a power driver doesn't give you that feedback so more boxes get crunched
Failure is always an option
 21 November 2012 11:52 AM
Martynduerden
Want a job ?
Martyn.
 21 November 2012 12:11 PM
Avatar for OMS.
LoL - as a summary:
Must turn up
Must work ... All day
Must not bugger off to do other jobs
Must be able and willing to do high quality
MUST NOT TWIST CABLES - that's my OCD
Must be able to do more than electrical work
Mush have a modicum of common seance
Must not winge when arriving home having missed neighbours
All of the above - you can get me for about £2K for a five day week
Must not smoke in the house
Priceless - I need at least one B&H an hour - I won't smoke in the house but my smoking rate is £80/hr pro rata - I need at least one 5 minute B&H session every hour
When do you want me to start -
 21 November 2012 01:34 PM
SherlockOhms
Well yes it's not hard to make a nice neat job of it but if ever a product needed a make-over it's this.
What's wrong with some nice, easy to remove, T+E shaped knock-outs and all in a material that isn't going to require you buying three times as many as you........ah, now I get it.
S.
 21 November 2012 02:05 PM
Martynduerden
LoL - as a summary:
Must turn up
Could about 2k be £800?
I reckon I could spare you 2 hrs a day for fags
Martyn.
 21 November 2012 02:19 PM
Avatar for OMS.
Well I could do the first 7 criteria for £800/wk
If you want some who won't moan about missing Neighbours then that's another £1200 -
I can smoke an awful lot of fags in 2 hours Martyn - 5 mins/hour will do me - think about it like a display screen equipment assessment - the advice is take a break every hour, so smoking is my way of complying - I thinks that points 6 & 7 covered -
Seriously - there must be some bugger on here looking for a week or so's work ?
 21 November 2012 02:24 PM
Martynduerden
2 hours was 5 minutes per hour maybe it was too cryptic
Martyn.
 21 November 2012 02:43 PM
Avatar for OMS.
LoL - I see, it's 24/7 then Martyn - that's almost as bad as my day job.
 21 November 2012 03:09 PM
bartonp
Sharp tap with pointly screwdriver, rake L&R to clean up sharp bits. 10 seconds, never broken one.
Must be a knack.
Phil.
