Topic Title: Number for Kent DNO required? Topic Summary: Created On: 16 November 2012 09:22 PM Status: Post and Reply |
Hi,
Im in kent (swale area) and I need to ring the DNO to confirm which earthing system is present at a site I work at. Does anyone have a number for the department I need to ring? Thanks Martin |
UKPN general enquiries 0845 601 4516
I'd recommend it might be less stressful for non emegencies sending an email to general enquiries which will get forwarded to the right department, with the installation adress and your contact details. |
--------you could run it by us forum members,
is it overhead? likely to be PME or TT, underground? old network, poss cable sheath (TNS) new-ish? 2 core? no sheath? its PME. dedicated t/x? transformer earth. Regards |
--------you could run it by us forum members, is it overhead? likely to be PME or TT, underground? old network, poss cable sheath (TNS) new-ish? 2 core? no sheath? its PME. dedicated t/x? transformer earth. Regards Or put four coloured balls in a bag with one labelled TT, one TNCS (PME), one TNS, one for haven't got a clue then get someone to pull one out. Stu |
Thanks for the replies.
I'll go the email route I think and se that way. The issue is on 5 cravans parks Ive been to look at. The supplies look like PME, which causes an issue if it is as the caravnas are all connected to it. I just want to confirm this before I report back to the client. Thanks Martin |
