Topic Title: 10 meter high scaffolding Topic Summary: Created On: 07 November 2012 09:56 PM Status: Post and Reply |
Got a commercial job,
On 2nd floor of a building there is a large open space, previously used for a factory production line. There is access by means of single door and straight onto a stairwell to ground level. Anyway powered access is a no go due to stairs, only access for powered equipment would be through a a set of large access doors and use of a craine . Is scaffolding possible for a height of 10meters? Don't fancy shuffling it about the room. ------------------------- Dougie Power Plus Electrical.co.uk My mission is to live as long as possible......so far so good! |
Either speak to the client about arranging scaffolding and quote on the bass that it will be in place, or speak to a friendly local scaffolder to obtain a quote, add a bit, and add it to your own quote.
------------------------- Regard Richard (Dick) www.rllewellyn.co.uk |
Some scaffold towers seem to go up to 14m (12m) high - e.g. http://www.scaffold-tower.co.u...ouble_width_3.2m_10x4/
Even for hire ones hit 10m http://www.hss.com/g/80400/All...ower-Addit.-1.0m.html (I've no connection with either firm, just a google results having been looking for a tower myself) - Andy. |
Try and get an aluminium one as they are lighter !
------------------------- Empty barrels make the most noise. |
Ive recently done some unistrut on the underside of a warehouse roof at 10m on a tower scaffold. Not too bad to put up as long as there is at least 2 of you. Not too woobly as long as you get lots of tension on the outriggers.
If you dont like heights though dont bother as 10m is the same as a 4th floor on a tower block or similar and a long way down. It will cost maybe 8 times more to get a fixed scaffold by a scaffolding firm. ------------------------- ---------------------------------------- Lack of planning on your part doesn't make it an emergency on mine.... Every man has to know his limitations- Dirty Harry |
I personally wouldn't entertain usin a mobile tower above about 5 meters. I don't like building them at the best of times, but certainly wouldn't fancy swinging a platform into place at that height, or indeed climbing up and down it with tools and equipment.
I personally, if powered access is out the question, would like a solid scaffolding to work on. If the price is to high, my competitor is welcome to the job! Ironically, I would rather harness up and swing out working off suspended ropes than on a mobile tower! Just what you are happy with I guess! ------------------------- Regard Richard (Dick) www.rllewellyn.co.uk |
