Topic Title: 3 phase board wanted
Created On: 27 October 2012 01:32 AM
hifly
has anyone got an old 3p+N board knocking about they don't want?
needs to be one i can still get mcb/s for.
I am just about to move house and i am going to get 3 phase put in to the workshop for the lathe and mill but trying to keep costs down as much as possible so used kit will have to do.
Cheers
Vince
Vince
 27 October 2012 08:04 PM
weirdbeard
Hi vince sorry, but haven't got anything suitable, just ideas.... When you say you are going to have 3 phase installed to the workshop, will this be a new dedicated DNO supply to the workshop? If thats the case I would have thought that the cost of a small low-end DB would be a tiny proportion of the overall cost!
If your property has 3 phase already and you are installing the supply cable from the house to the workshop yourself, with a view to cutting costs do you really need a proprietary 3 phase DB in the work shop?, I've just helped do a similar job for my neighbour who bought a 3 phase compressor, we ran a 32A 3 phase cable into an enclosure with a 4 pole 30mA RCD, then through a 20A 3phase mcb to a socket to which he can choose to run his compressor, or some other appliance if he gets any in the future, and for the small power we connected a cheap split load dual rcd board into the supply side of the 4 pole RCD for the lights and general sockets. This installation has the benefit of 3 way multi-pole RCD protection which is not cheap or easy to achieve with a standard 3phase db
 27 October 2012 08:42 PM
hifly
I know where you are comming from with the cost of the install etc but its just another £200, I suspect there are a lot like me that have a "collection" of bits around just in case they come in handy or looking for a good home ;-) and as they say the best recycling is to reuse.
I don't work on 3 phase as i just do domestic, so i don't have any kit laying about. like others may have.
currently its just for my lathe but i will be getting a milling machine and possibly a few other bits of kit that will be 3 phase, the less i spend on stuff the more stuff i can have.
Vince
 27 October 2012 09:04 PM
weirdbeard
Hi vince, just another idea, theres a website called 'freecycle' try sticking a 'wanted' advert on there in your area- you never know what might turn up!
 27 October 2012 09:18 PM
hifly
yes, i do a lot on freecycle, might be a bit too far off the "bedside tables & kids cloths" as we are a bit in the sticks but worth a try.
Vince
 27 October 2012 09:25 PM
weirdbeard
Out of interest, won't hold it against you..... does your new property already have 3 phase?, if not whats the cost of having it installed?
 27 October 2012 09:30 PM
weirdbeard
Ps re the cards, do you print them yourselves or sub it out - reason is my mrs wants a good price for maybe 1000 of her own design.
 27 October 2012 09:32 PM
hifly
no, not at the moment,
no idea of cost as we only got the keys yesterday, i will be running my kit from a rotory inverter i made for the time being but the aim is to have 3 phase installed, i even have the overhead cables running above the workshop,, i was thinking a few croc clips and i would be in business.
Vince
 27 October 2012 09:37 PM
hifly
I use a local printing company, that way when i have a new design i can pop down with the jpg on a memory stick and get them to print one as a sample to make sure the colours are correct, belive me they do not always come out as you expect so its worth getting a couple done so you are happy with the colours.
Vince
 27 October 2012 09:43 PM
weirdbeard
Hi vince, really compared to the cost of having 3 phase installed, for a small user most machines are available in single phase - you might be aswell cost wise to sell your 3 phase machine and change it for a single phase version - 3 phase has most benefit to spread the load where there might be several or many machines in use simultaneously
 27 October 2012 09:45 PM
weirdbeard
Thanks for the info
 27 October 2012 09:55 PM
weirdbeard
Also vince, I don't know this for sure, but you might also find there is a higher standing charge for having a 3 phase supply, which for occasional use you may not find economical.
 27 October 2012 10:06 PM
DOUGIE1000
Few yr back my neibour wanted his new lathe wired up. Upon investigation course it was 3ph in a domestic shed.
Few weeks later he produced (see link bellow) and now not only have I done his but also most of his mates garages too.
All works great and as variable speed guys seem to give it a big thumbs up.
http://www.ebay.co.uk/itm/IMO-...ET&hash=item4d05c1d02f
Dougie
Power Plus Electrical.co.uk
 27 October 2012 10:51 PM
hifly
yes i know about these but they won't provide 3p+n only 3p, the lathe i have is a 1956 vintage that i want to keep original and requires 3p+n
Vince
 27 October 2012 11:40 PM
weirdbeard
Hi vince, i admit I know nothing about 1956 lathes, but why does it need a neutral? is it for powering a lamp?
 28 October 2012 12:05 AM
hifly
No not a lamp, it has a dc motor that feeds the carrige and cross slide where the main motor is 440v 3 phase 2 speed and the feed motor is powered from 1 p+n via a variable speed controler that is part of the original lathe.
It would take a lot of rewiring to change it, the main motor is a very high presion motor made only for this make of machine, changing to a standard single phase unit is not what i want to do.
The other point is that you realy need 1 static inverter for each piece of kit and as my plan is to have a number of 3 phase machines i feed a 3 phase supply is the best option for me, thats not to say i can't save some money where possible by using second hand kit where i can.
and then there is the supply to the garage, but thats another story.
Vince
 28 October 2012 12:17 AM
DOUGIE1000
Generator for 3phase stuff, and lights sockets, tea urn etc on house supply :-)
Dougie
 28 October 2012 01:08 AM
hifly
yes that is an option, i would still need a dist board ;-)
Vince
 28 October 2012 06:31 AM
normcall
I have a Wylex board - brand new , all it's had is a hole drilled in it. A couple of TP mcbs and 100A main switch.
If you are interested, then PM me and I'll go and find out exactly what model etc. I think it's a 12W (4*3) plus neutral and about 5 years old.
Norman
 28 October 2012 10:23 AM
WiredScience
My last house had a 3 phase head, but only a single phase used. The quote to upgrade to 3 phase (new meter and two fuses!) was £1700 +VAT. I decided I could buy a few single phase machines for that price...
IET » Wiring and the regulations » 3 phase board wanted
