Topic Title: Speeditest
Created On: 29 September 2012 08:54 PM
frspikeyhead
Anyone come across or tried using the TIS 999 speeditest. CEF have them on sale in their shops. It claims to save up to 20mins on testing each ring main. All the tests are carried out from one point of connection, either the board or a socket. However, my concern is how can you say you've adequately tested out all the tests on a ring main from one point?
 29 September 2012 09:13 PM
Not seen or tried one, so I Googled it http://www.testinstrumentsolut...ert%20-%20SpeediTest[1
it looks like it could take twenty minutes to null it in its various possible combinations
Andy
 29 September 2012 09:23 PM
Davesparx
If it takes you 20 mins to test a ring main then all hope is lost
 30 September 2012 10:42 AM
On a new instal. Davesparx i'd agree but in an existing one it could take that long just to find all the hidden sockets to un-plug everything, plus fcu's feeding things!
 30 September 2012 01:22 PM
Grobbyman
But. You are still going to have to do all that aren't you?.
 30 September 2012 01:46 PM
I reckon I can move the croc clips round fast enough to not need a switch box.
Perhaps it's designed for our 5 day friends who only need to connect the meter and the 6 leads then twiddle
 30 September 2012 02:03 PM
Surely with this device, you are going to need to regularly test and keep records of the resistance of each switch contact resistance too?
 30 September 2012 02:16 PM
potential
Anything that gets between the test meter and the circuit being tested is almost certainly going to introduce additional resistance and problems associated with poor connections etc.
It may look fine on paper and work in theory but in practice it is probably not a good idea..... unless the "electrician" doesn't know how to operate the meter and place the leads to conduct the tests correctly.
 30 September 2012 04:47 PM
frspikeyhead
That's my point entirely, I don't think it is a good idea as it reduces testing a ring to one point only, which some I dare say think is adequate, whereas your still going to need to test R1R2 and R1Rn at each point to ascertain whether there are interconnections and spurs etc.
 30 September 2012 05:59 PM
dickllewellyn
I believe metrel make a meter which does the same thing but automatically within the meter. If speed of taking readings is what your after, maybe it's got a place, but personally I find it quick, easy and thorough to test my ring and cpc continuity at a socket outlet, then figure eight link using the sockets terminals and manually check readings at all the outlets on the circuit.
I guess if you have guys on site doing instalation and testing, then it could be usefull as qs to quickly check the numbers aren't made up.
Richard (Dick)
