Topic Title: Can I carry out EICR Topic Summary: Created On: 26 September 2012 07:44 PM Status: Post and Reply |
Hi, just finding out from regular sparks if I can supply the necessary
test cert that would satisfy a landlords certificate? I am a qualified Approved electrician and semi retired and have taken and received 17th C and G but have not taken 2391. I do a few installations per year but mostly Industrial and Agricultural so have not taken part P as if I do a domestic installation I notify building control. The question is I have been asked to carry out a test and report on a rented property for a family member and produce a cert for the landlord. I assume this is EICR form 6 ? Am I allowed to do this and if so how far do I take it with regards to full inspection including continuity on ring mains , or should I call in a NEIC or similar contractor? Many thanks in advance for advice. Stillon 7029 |
I do a few installations per year but mostly Industrial and Agricultural so have not taken part P as if I do a domestic installation I notify building control. Part P doesn't apply to EICR's. Anyone can carry out EICR's, but it's your signature on it, so needless to say, you need to know what you're doing. As to the extent of testing required, agree it with your customer beforehand. |
Stillon, I take it that you and your client are aware that there's no legal requirement for a landlords certificate for electrics in a rental property?
(unlike gas!) Dave. |
Stillon, I take it that you and your client are aware that there's no legal requirement for a landlords certificate for electrics in a rental property? (unlike gas!) Dave. Tut, tut. It's an EICR. Landlord certificate is the tongue of the landlords!! As for the OP. As stated anyone can carry out an EICR but do you have the experience, insurance and knowhow? You've got to be willing to stick a signature on a report stating it's satisfactory for ALL who use for the period of time you'v written on the report. |
Mike, thanks for the info, to satisfy the periodic inspection should I just use forms 6 or should I also use 4 and 7? With regards to customer/relative they will go for which ever is needed as they will want all full stops dotted and t's crossed
Dave thanks, no I did not know that there is not a legal requirement for a landlords cert , how ever this is the 5 year PI inspection which is advised on rental property.( Sorry should have stated PI not landlords cert ) Thanks PS Thanks Rutts just dusting off the Quill !!! Edited: 26 September 2012 at 09:58 PM by stillon7029 |
The OP mentioned a landlords certificate Rutts, I was just pointing out that it was not required. A chap I know has several properties that he lets out through the local council and they are quite happy with the visual reports I do for him,
Dave. |
I was only jesting Dave. Hence the smiley.
What ever form they take be it visual or otherwise they are still a report. At the end of the day, it's whatever the customer is happy to pay you for. |
Agreed Rutts, I do try to avoid doing EICR's, far too much responsibility I reckon especially since the changes earlier in the year. I do quite like doing the visual condition reports though although I do a bit more than is asked for on the form, eg some Zs tests and usualy a Ze test too. I usualy get some remedial worrk too which is handy,
Dave. |
I don't mind EICR's too much. Especially on rentals when they're empty. No overheads plus, as you've mentioned, remedials. You pick up a nice little bit of work from em.
It's occupied, furnished houses that are a pain. |
Thank you for the info, it was to find out if I could officially do it.
You can do it.
The only problem, is whether whoever the EICR is for will accept it. The Local Authority where Daveparry is, accept his visuals, whereas in my area, the Local Authority will only accept reports from scheme members. |
