Topic Title: Boiler Wiring Topic Summary: Why must you have a pump neutral? Created On: 25 September 2012 08:14 PM Status: Post and Reply |
So what does he think it should be OS, IP66 in case the boiler leaks! They are a joke aren't they.
on another note i normally fit a 3 pole fan isolator next to the boiler for isolation if the spur is else where. a customer rang me to say she had the boiler commissioned and the engineer told her it was dangerous because the switch next to the boiler was not the correct one.. so this is telling you what gas fitters know about electrics.. Might be better if your isolator was marked boiler isolator, rather than fan isolator! |
"on another note i normally fit a 3 pole fan isolator next to the boiler for isolation if the spur is else where. a customer rang me to say she had the boiler commissioned and the engineer told her it was dangerous because the switch next to the boiler was not the correct one.. so this is telling you what gas fitters know about electrics.."
They like to be able to take the fuse out of a SFCU and put it in their pocket, then tie a warning sign to the withdrawn fuse holder of the SFCU with a cable tie, or so I've been told. Andy |
i fit MK ones they only say isolator on them
anyway they shouldnt be in the boiler if they dont know what they are doing, lack of training i recon on another note i normally fit a 3 pole fan isolator next to the boiler for isolation if the spur is else where. a customer rang me to say she had the boiler commissioned and the engineer told her it was dangerous because the switch next to the boiler was not the correct one.. so this is telling you what gas fitters know about electrics.. Might be better if your isolator was marked boiler isolator, rather than fan isolator! |
Boiler Wiring
