Topic Title: Old C50 fuseboards Compliance
Topic Summary: Old C50 Fuseboards,
Created On: 17 September 2012 10:30 AM
BILLYBOY65
Hi
Have come across a load of old C50 Db's in a School, can anyone think of reasons to fail them in a EICR ?
Other than,
Exposed busbar inside.
Can't get spares
Unable to fit RCBO's for Socket outlet circuits.
Unable to lock them.
Cheers
Billy
 17 September 2012 11:36 AM
Avatar for davezawadi.
davezawadi
Those are not competent reasons Billy.
Which regulations are not met?
David
Avatar for OMS.
Originally posted by: BILLYBOY65
Hi
Why would you be looking to fail them - isn't an EICR a report on the installations condition for continued service ?
Other than,
warning label ?
Can't get spares
Not really an issue for a EICR - what regulation does it breach ?
RCD's in seperate enclosures adjacent or at the point of room entry or RCD sockets - do you need them at all?
Lock the board isolator or lock the source end supply ?
Cheers
Billy
You could mention the issue of obsolescence in a report accompanying the EICR - but that's an issue for resilience not the EICR
Failure is always an option
 17 September 2012 12:15 PM
Avatar for BigRed.
BigRed
If we are going to fail things for being obsolete, thats a hell of a lot of boards out there that need changing....
C50's can be locked if you have the kits.
Are you testing as part of a company, or as your own company?
 17 September 2012 12:28 PM
Avatar for spinlondon.
spinlondon
Is there a requirement to fit RCBOs on socket circuits?
When did that happen?
 17 September 2012 02:40 PM
normcall
Last time I looked, C50 mcbs were still available from Crabtree.
Norman
 17 September 2012 03:31 PM
John Peckham
I have not seen a Crabtree board where you can access the bus bars inside without the use of a key or tool.
I will get me coat!
John Peckham
 17 September 2012 06:04 PM
davezawadi
I really don't think its you that needs the coat John!
It seems to be the rest of the industry, (not those posters on this thread BTW).
David
 17 September 2012 06:10 PM
Avatar for OMS.
I will get me coat!
Maybe not John - but I believe you testing chaps like to work live with the DB cover off for certain tests - I'd comment on the lack of busbar protection personally - but again an observation rather than a "non com"
It's what we call in some sectors "characterisation" - as in " I'm away to undertake characterisation of the switchgear in facility XYZ "
 17 September 2012 08:20 PM
davezawadi
Which regulation OMS? Yes we work live sometimes because the tests demand it, but there are no live bits available without the use of a tool. This is simply life, and to say that live testing is not permitted (whatever HSE / CDM etc. thing you like) is simply impossible. Can I only test a substation dead, no injection testing of protection etc.? Is this some idea of utopia? What follows is "when I connect the grid to the load will it go bang"? Good question!
David
 17 September 2012 09:07 PM
Avatar for slittle.
Generally... "It's your turn to do the switching, I'm off"
 18 September 2012 08:48 AM
Avatar for OMS.
As I said David - an observation by a competent engineer
Indeed - so the non competent are protected, they can't open the box - that doesn't mean there is no duty of care owed though - I'll bet you can't give me a regulation relating to manual dependant switchgear - but as a competent person you'd expect me to comment on it ?
Really - I guess you haven't followed EAWR then - is it reasonable in all circumstances for it to be live - is it unreasonable in all circumstances for it to be dead and what mitigation has been put in place. A live busbar is clearly a risk that can be mitigated
Well you know what tests are required and where/when - is it unreasonable of me to specify thermal imaging screens for example - it's an acceptable test method and reduces thequantity and duraton of live access/live testing.
Not really David - there are many ways to achieve confidence that an installation is safe to put ino service and for continued service - the world of electrical installation does not begin and end at BS 7671 does it ?
 18 September 2012 12:28 PM
davezawadi
I'm not going to rise to that OMS, but using your comments as a basis I could probably condemn half the installations in the country. However such large scale rewiring would probably finish us off completely economically, as almost everything is imported!
David
 18 September 2012 02:39 PM
Avatar for OMS.
I'm sure we could condemn half the installations in the country - that doesn't really mean that issues of safety are not worthy of comment though does it. I'm not suggsting we rip out every C50 board - just that the relevant comment is made to the duty holder under EAWR - to do less is failing in a duty of care owed by a competent person to his client ?
