Topic Title: MEM EATON MEMGUARD Dist Board 240v 12 Way
Topic Summary: MCB's versus RCDS / RCDO's
Created On: 29 August 2012 05:42 AM
Ed Whelan
from a jurassic electrician (lapsed) with a JIB approved electrician ticket with C&G / YHCFE certs
living in land of smiles with a Dist Board having MCB's fitted, all over sized, want to change to correct size & type for circuit - safe ma trip value that will not be a nuisance, considering many varients for earth protection here e.g. no earth rod no earth - earth rod with earth connected - earth rod cross connected to earth & neutral - et al; am lucky as sockets / cooker / washer / water heater are ALL earthed (lose phrase), but light fittings are not; can't win em all ...
I contacted MEM USA/UK (both are silent) & BGK today who advised that they do not manufacture RCD's or RCDO's
Can a modern day electrician (pref with land of smiles experience) please advise me which manufacturer can supply MCB's - RCD's and type that will give max protection
 29 August 2012 07:37 AM
crossy
For those who don't know, the Land of Smiles is Thailand, and it's bloody wet right now
You got a photo of the board Ed? Most of the local suppliers do the plug in Square-D type or the normal DIN mount MCBs. It may well be easier to replace your CU with a locally sourced one where you can actually get breakers that fit.
You should be able to get RCDs and RCBO's (both single and 2 pole) from your local electrical emporium, have a look on the Haco Thailand website for photos and Thai language details. http://www.hacothailand.com/
Edit, the Haco site only works properly with Internet Explorer.
 29 August 2012 07:58 AM
Ed Whelan
thanks crossy, dry here mid south of T
2 pics on way via email, mcbs are plug in single pole
HACO likes FireFox ...
 29 August 2012 10:13 AM
Well the Distribution Boards with built-in Picture Frame (http://www.hacothailand.com/pr...=3&setype2=&txtsearch= ) did make me smile!
 29 August 2012 10:45 AM
marclambert
What a great idea
'course you could always "frame" the schedule of test results! That'd stop 'em being lost in the kitchen drawer
 29 August 2012 01:03 PM
crossy
I've not seen that type of board in any of our local electrical emporia, that said yours must have come from somewhere, maybe pop a spare breaker out and head to the village sparks shop.
Assuming you fail, a couple of choices:-
1. Replace the board and build yourself a split-service CU from available parts, ours is a pair of 16 way ABB proM boxes in order to get in all our breakers and surge protection, readily available parts but a bit of DIY needed.
2. Use your existing board and add whole-house RCD protection. The local brand Safe-T-Cut do purpose designed RCBO units, http://www.safe-t-cut.com/eng/...hp?name=product
You may also like to have a look at this PEA document http://www.pea.co.th/pdf/groundwire.pdf yes I know it's in Thai but it shows how they will expect your earth rod to be connected (incoming neutral via the ground bar NEC style).
Edited: 29 August 2012 at 01:14 PM by crossy
 29 August 2012 03:43 PM
Ed Whelan
tks crossy, I'll do the business and feedbak FYI
