Topic Title: Element change in a pressurised HW system.
Topic Summary: Any special precautions.
Created On: 24 August 2012 07:50 PM
breaker
Hi
The title of the post says it all are there any special precautions or routines to adhere to?
 24 August 2012 07:56 PM
Grumpy
Do you mean a standard domestic unvented cylinder? If so, then no. Turn off the cold feed to the cylinder, open some hot taps, stick a hose on the drain off cock (which will operate seamlessly and definitely won't be stuck closed) open the t&p relief valve to let the air in and away you go.
 26 August 2012 07:46 PM
aligarjon
i would recommend loosening the element before you drain the tank.
Gary
 27 August 2012 03:25 PM
baldelectrician
You need a ticket to work on uvented cylinders, most plumbers run a mile as the possible repercusstions if something were to go wrong are grim
http://www.youtube.com/watch?v...a60Ypg&feature=related
baldelectrician.com
