Topic Title: Consumer units
Created On: 18 August 2012 06:48 PM
1 2 3 Next Last unread
brianrhurst
Hi can anyone tell me if domestic consumer units have to be installed horizontally ? I have a new unit to install except the meter has been placed in the top corner of the enclosure with the cut out below, leavin no room for a new unit above it, the only place I can put it is to one side but it would have to go vertically, is this acceptable?
 18 August 2012 06:58 PM
We've discussed this several times in the past and I think the general opinion is that it's ok, bearing in mind that some of the larger commercial type boards have the mcb's mounted horizontally anyway,
 18 August 2012 07:09 PM
Avatar for Dave69.
Dave69
they should be mounted as per manufacurers instructions
 18 August 2012 08:50 PM
Avatar for colinhaggett.
colinhaggett
Hope this isn't the meter cupboard?
 18 August 2012 09:16 PM
brianrhurst
Yes it is the meter cupboard the old cu is a wooden back wylex board which are much smaller as you know, and is tightly packed in above the meter there is not enough room for a new board, hence why I need to mount it vertically or mess about getting the meter moved at more cost to the customer.
 18 August 2012 09:18 PM
brianrhurst
Thanks Dave, that's what I thought as most 3 phase boards have there mcb's or rcbo's mounted that way.
Many thanks
Brian
 19 August 2012 09:51 AM
Avatar for OldSparky.
OldSparky
will look strange but would be ok
 19 August 2012 12:30 PM
Avatar for Dave69.
Dave69
like i said it MUST be installed as per manufactures instructions, i am sure there is something in the bible we all work to that says that and remember some boards even come with a handy buble so you can try to mount them almost level, not on their side
 19 August 2012 12:53 PM
I don't remember ever seeing any reference to mounting positions in c/unit instruction sheets Dave, and the ones that i've used that have a spirit level supplied have had it as a loose item so it could be used in either orientation. Although the pictures usually show horizontal mounting i've never seen it mentioned that they must be mounted that way,
 19 August 2012 01:38 PM
Avatar for dg66.
dg66
So lets say you came across one on an EICR what code would you give it?
Dave(not Cockburn)
 19 August 2012 06:33 PM
OldSparky
none,, whats the problem with it, so long as you could read the circuit chart..
 19 August 2012 06:41 PM
Agreed OS!
 19 August 2012 07:24 PM
brianrhurst
Thanks everyone it's going in on it's side tomorrow, I've checked the data sheets for the cu I'm installing and no where does it say that the unit cannot be installed vertically, thankyou for all your comments.
Brian.
 19 August 2012 10:59 PM
Avatar for dg66.
dg66
Agreed OS & DP , hence the question to dave69
Dave(not Cockburn)
 20 August 2012 09:08 AM
Avatar for ebee.
I would say there are two considerations here :-
1/ Some manufactures make the MCBs to go in 3 phase boards horizontally so in that case operationally I see no problem.
2/ Expectancy - in a single phase CU the expectation (and the labelling) is for vertical - would a "ordinary person" be unduly confused by this and therefore safety impaired?
 20 August 2012 07:06 PM
Avatar for Dave69.
Dave69
Thanks Ebee, it seems like you are almost agreeing with me, As I keep saying a CU should be installed as per manufactures instructions, look at the pictures and they all show them horizontal, the labels are designed for horizontal.
If a CU was deigned to be mounted vertical dont you think the "key hole slots" for fixing would reflect this.
If you look at the spec for consumer unit it will give the size as
1) Width
2) Height
3) Depth
so that will again tell you which way it should be mounted so if you mount it any other way it is worth checking with the manufactures that it still complies with BS EN 60439-3
I am not saying it is dangerous to mount a CU vertical, but I AM saying it is bad practice and poor lazy workmanship.
If it wont fit move it
Edited: 20 August 2012 at 08:17 PM by Dave69
 20 August 2012 09:01 PM
Avatar for dg66.
dg66
So what code on an EICR?
Dave(not Cockburn)
 20 August 2012 09:13 PM
None! What code would you give a 13amp socket that was mounted vertically due to lack of space? Not very common I know but sometimes seen!
 20 August 2012 09:19 PM
Btw, i'm not saying it would look very good and i've never done it myself but sometimes situations promote non-standard approaches don't they, (c/units, sockets or whatever)
 20 August 2012 10:44 PM
Avatar for dg66.
dg66
The EICR question is aimed at the posters who think there is a problem with mounting the CU on its side
Dave(not Cockburn)
IET » Wiring and the regulations » Consumer units
