Topic Title: meters Topic Summary: recommended Created On: 10 August 2012 12:33 PM Status: Post and Reply |
Hi all
Im looking to install a meter before a 160A three phase sub board. Any one recommend a decent meter and ct's. Cheers |
Secure Meters Ltd
PRI House Moorside Road Winchester Hampshire SO23 7RX. Ask them for a CoP 5 compliant meter and they also give you the correct CT's No connection btw - we just specified loads of them on a recent project regards OMS ------------------------- Failure is always an option |
should I know what cop 5 is
Code of Practice 5 (Meters) - look for Measuring Instruments Directive (MID)
You may not need that if you aren't billing someone for the energy supplied - but it does give you a good gaurantee of acuracy etc I mentioned it in response to your 160A supply - being over 100kW Regards OMS ------------------------- Failure is always an option |
Universal metering services do a ct meter with various sized ct's too.
If you look them up on the web you'll find them. No connection other than we buy a few from them for farm sub metering Stu |
Thanks to the above
Autometers up in manchester do a wide range of meters.
I've installed and used the IC970 and am impressed. http://www.autometers.co.uk/pr...-mounted-meters I have no connection either other than having fitted 100+ of these. Alan C recommended: http://www.owen-brothers.com/ and in my case - they do a fantastic metal clad enclosure, to which I fit all the autometers equipment. I know they do the whole package of meters, enclosures, CTs etc. They are certainly very nice to deal with. I've had a very personal service and have dealt directly with the owner. Cheers. Tatty Edited: 13 August 2012 at 08:44 AM by tattyinengland |
meters
