Topic Title: RCDs
Created On: 02 August 2012 08:43 PM
<< 1 2 Previous Last unread
 04 October 2012 09:44 PM
weirdbeard
I've been thinking again about this one. 705.411.1 (by the numbering) is modification to the requirements of section 411 - i.e. ADS.
Must admit that although i've worked on farms in the past for employers, it's only fairly recent that i've had to get stuck into the regs concerning these - just having a quick look at the 16th and the system in that seems a bit more common sense - ie where the special location requires something different to the standard regs it often says reg xxx-xx-xx is relaced by reg 605-xx-xx.
 04 October 2012 10:45 PM
OldSparky
if you think about it all tails on a TT supplies are un protected...
 05 October 2012 10:18 AM
Not protected by ADS, but hopefully protected by double or reinforced insulation or equivalent.
 07 October 2012 07:39 PM
weirdbeard
Originally posted by: slittle
Bear in mind you won't get a PME connection anyway so you've got to TT it and the first protective device on a TT has to be an RCD.
From a description by the owner, it sounds like it's going to be TN-S, he says theres a separate earth cable been run between the intake and the transformer, that has been staked at several points in the trench, though I've yet to confirm this with the authoroties.
IET » Wiring and the regulations » RCDs
