Topic Title: Neutral Colour Topic Summary: What colour neutral are other panel builders using ? Created On: 30 July 2012 02:21 PM Status: Post and Reply |
Hi,
We generally use a 'light blue' neutral inside our control panels for the neutral conductor as per BSEN60204-1, where it quite clearly requires this if no other form of identification is used. It does not however, inform us what colour to use if we identify it by any other means (critchley markers etc.) We had a panel recently with a larger than usual transformer inside that required us to use 16mm2 light blue cable, but we could not get hold of any. This would indicate that no one else uses light blue at such larger sizes within their control systems. So what colour does everyone else use ? Red ? Cheers, Bob. |
Hi Bob,
Grey would seem a suitable substitute, ringed, possibily with some blue sleeving Legh ------------------------- Why do we need Vernier Calipers when we have container ships? http://www.leghrichardson.co.uk "Science has overcome time and space. Well, Harvey has overcome not only time and space - but any objections." |
Most of the control panels we receive, use black with ID labels/markers
Regards Jobbo |
Ac volts - red. Dc volts blue
All numbered up ------------------------- Keep up with the antics of the UK,s most humoured electrical company Facebook: https://www.facebook.com/RtIndustriaLtd Twitter: @rtindustria |
If the neutral is part of a mains voltage circuit, as is likely if as large as 16mm, then ordinary blue conduit cable or tri-rated switchgear cable seems to be the norm.
If the neutral is part of an extra low voltage control circuit, then white, or blue with white tape, or white with blue tape all seem to be common. |
A good look at bs 6231 mayhelp too.spec for pvc insulated cables in switchgera and control panels. PM me if you get stuck trying to find it.
You got a copy big red ???? Wouldent mind a peek am in doubt now
Neutral Colour
