Topic Title: Blue Tack use to keep a connector in place
Topic Summary: and other pics
Created On: 24 July 2012 03:28 PM
Avatar for sparkiemike.
sparkiemike
Just completed a rewire, whilst stripping out took a few pics of what was uncovered.
Pictures on flickr
 24 July 2012 04:03 PM
Avatar for potential.
potential
It is quite possible that when these installations were made there was no such thing as a safe zone.
Maybe even before good practice so-called.
Edited: 24 July 2012 at 04:52 PM by potential
 24 July 2012 04:24 PM
Avatar for OMS.
There was never a time where running a cable at 45 degrees across the wall was ever good practice - it was rough then and rough now.
I love the blu tak though - classic
Failure is always an option
 24 July 2012 04:49 PM
potential
I don't disagree.
But good practice and safe zones are not the same thing.
I recall looking over a house being built by a popular building firm in the mid 80s.
There was hardly a single vertical or horizontal run of cable anywhere.
 24 July 2012 04:56 PM
Avatar for OMS.
Didn't we have good practice before we had safe zones then
I guess the old saying about regulation being two steps behind the cutting edge of worst practice is reflected in the practices of a popular mid eighties building firm
Surely it's not just BlueTac, but the latest fire warning compound from the US (where they know about electrical fires). The theory goes that joints are the weak point in the electrical system and will heat gradually as the joint loosens over time. Rather than wait for the temperature to get high enough to cause problems, the compound at a much lower temperature emits a distinctive oily-chary sort of smell - allowing the householder to locate and repair the problem before it turns into a fire hazard.
(maybe)
 24 July 2012 05:09 PM
Jaymack
Pictures on flickr
Probably green paint from the ceiling or gunge drained into the scruit?.
 24 July 2012 05:43 PM
Avatar for BigRed.
BigRed
local stockists now stock screwits from ideal...
 24 July 2012 07:59 PM
Avatar for stateit.
stateit
I've found 50-year old Scruit joints in better condition than 50-year old JBs...
Never found one with Blu-Tack though!
S George
http://www.state-it.com
 24 July 2012 08:46 PM
sparkiemike
Pictures on flickr
It was definitely blu-tack, not green gunge or paint.
 25 July 2012 04:36 AM
Jaymack
Who does the nails?
http://www.flickr.com/photos/2...ets/72157630728589256/
 25 July 2012 08:17 AM
sparkiemike
Who does the nails?
huh? that light fitting is fixed with screws not nails!
 25 July 2012 08:56 AM
potential
Are you sure it is blu tack?
I have come across pyrotenax potting compound in a similar situation.
BTW has anyone used pyro twist?
what was it like to install?
 25 July 2012 10:46 AM
Avatar for tomgunn.
tomgunn
Compounds more greeny... the best use for Blue Tax in the electrical world is for removing GU10 lamps... those stupid suction cups are useless... so wot ya do is to make a cone shaped piece of Blue Tax and push it on to the GU10 lamp... comes out a treat.. so it does!!
regards...
Tom
Tom .... ( The TERMINATOR ).
handyTRADESMAN ... haha
Castle Builders
Why did Nick Clegg cross the road? Because he said he wouldn't!
I can resist anything..... except temptation! ( Karl Gunn ).
 25 July 2012 10:54 AM
potential
Not always.
I have used both grey and a blueish potting compound in the dim and distant past.
I like the idea for GU10 lamps.
Funnily enough I have used potting compound to remove pigmy lamps when fitted in deep-tubed indicator displays in exactly the same way.
 25 July 2012 11:47 AM
Avatar for ebee.
Good tip that blue tack.
Thanks for that.
Advice like that makes the cost of subscribing to this forum well worth the annual rate.
 25 July 2012 11:59 AM
Avatar for rocknroll.
rocknroll
Pyro twist was only specified for certain applications where there were concerns about EMC noise, the termination was exactly the same as standard MI cable, although sometimes two part resin was specified instead of compound.
"Take nothing but a picture,
"Oh! The drama of it all."
 25 July 2012 12:29 PM
potential
Thanks for that.
It was the actual working with the cable that I was interested in, particularly the finishing off of the spiral cable in the pots.
I would imagine the spirals could pull out the mineral insulation when sheathing up and terminating.
 25 July 2012 02:28 PM
perspicacious
"Who does the nails? "
"huh? that light fitting is fixed with screws not nails!"
That manicurian (sic) admiration was varnished over
BAD
 25 July 2012 02:41 PM
Avatar for OMS.
Glossed over, I would say, BOD -
