Topic Title: isolation switch for pir flood light
Created On: 03 July 2012 05:47 PM
peajay
Hi all does any one know if an isolation switch is needed for a pir flood light.
 03 July 2012 05:59 PM
Doesn't have to have one but it's very useful, saves turning off the complete circuit for maintenance plus most pir lights have an override facility which is activated by switching on/off/on whithin a certain time,
dave.
 03 July 2012 06:02 PM
peajay
But its where to put one on the premises without it looking ugly.
 03 July 2012 06:46 PM
mikejumper
On more than one occasion I've been called to look at a 'faulty' PIR floodlight, only to find that someone has switched it off.
They usually then say; 'Oh I always wondered what that switch was for'.
If you can fit one and clearly identify it, then I'd say it's worth doing, otherwise not usually needed.
 03 July 2012 06:47 PM
Avatar for OMS.
Start with the security considerations - if you provide a nice masterseal switch adjacent to the floodlight, any little toerag can switch of the fitting with a brush handle !!
You don't really need one for isolation - operationally, an internal lightswitch might be useful
Failure is always an option
 03 July 2012 08:22 PM
Grumpy
They can be very handy when they go wrong, I've found them to be the most unreliable little buggers. It's helpful to be able to turn them off when the sensors fail so that they're not blasting out 500W 24/7. Personally, I always install a switch with a big label on it somewhere out of the way.
 04 July 2012 11:37 AM
Avatar for jsa986.
jsa986
In answer to your question No it is not needed.
www.icertifi.co.uk
BS 7671 electrical certificates on your iPhone/iPod
www.tapengines.com
Electrical apps for electricians and engineers on iPhone & iPad
 04 July 2012 12:00 PM
But very useful!
 04 July 2012 12:23 PM
ArthurHall
A suitably IP rated 16A plug and socket next to the fitting is handy for local isolation. Also makes it easy to take the fitting down to free off corroded screws etc.
 04 July 2012 08:31 PM
mikejumper
Handy also for plugging your lawnmower in if you've got one of those Eco houses with a grass roof; saves hoisting the goat up there every month.
