Topic Title: Presence detectors in public toilets
Created On: 25 June 2012 08:43 PM
chriso
Hi guys/gals,
I've been asked to price for presence detectors in a village hall's toilets. Typical arrangement, in through main door, then inner privacy door, into main area of urinals/basins with 2 toilet cubicles on the far side. In total the size per toilet is probably no more than 7x3.
I was thinking of 1 x main microwave presence detector in the hope that it could be fitted on ceiling of the main central area and tuned to detect in the cubicles and entrance section as well as the main area.
Has anybody tried and succeeded at this? Or should I just fit 3/4 x standard presence detectors (one above each area)?
Advice gratefully received
Cheers
Chris
 25 June 2012 09:15 PM
peteTLM
Yes ive done both timeguard and some posh german make that i cant remember. Dual channel fitting, 1 channel for lights and 1 channel for vent.
Not had any complaints, but they are set at 15-20 minutes anyway as public building.
1 job they controlled a load of halers fittings, the other one philips led fittings
 25 June 2012 10:50 PM
Avatar for Martynduerden.
Martynduerden
Repost.
you could try
Hager Tebis
KNX
Setsquare Setsquare are mainly presence based, there are a few sensors available.
Dali
Lutron though if you have a problem its most definatly YOUR problem
AMX very good systems, full controls on Richard Branson's Boat!
Simmtronic
Just a few to be going on with most are commercial based but offer home solutions.
Martyn.
 25 June 2012 10:57 PM
chriso
Thanks for the responses, I'd been looking at a Luminite SMW360.
Wondering whether it could be set to read through the privacy door, so that it picks you up when you walk through the first door. The privacy door is quite light and flimsy, equally the doors to the cubicles are pretty slim.
Just don't want to go ahead and then not have it function 100%!
Chris
 26 June 2012 12:02 AM
Avatar for sparkingchip.
or be caught in the dark with your trousers down!
Andy
 26 June 2012 07:16 AM
Fm
Dalers as well with a no neutral required version
 26 June 2012 07:43 AM
Avatar for Rulland.
Rulland
Motion sensors in the cubicles...............;-).....sorry!.
 26 June 2012 09:06 AM
chris1982
Andy
tell that to the hotel i stayed in last year on holiday, their electrician hadn't thought the job out as well as the people in this thread
 26 June 2012 11:26 AM
Avatar for BigRed.
BigRed
Think tank in brum has one sensor by the door...on a 3 min timer.....dont ask how i know...:-)
 26 June 2012 01:10 PM
impvan
Microwave sensor should cover the whole room without any need for aiming or masking. I'd leave one light connected to the normal switch to give some background light, change to led if efficiency is an issue.
 26 June 2012 02:14 PM
Avatar for OMS.
Before you start, check if you are not wasting your time or the clients money.
I was working on a zero carbon developement fairly recently and the initial brief was occupancy sensing in all WC's (and store cupboards).
We challenged it and offered to monitor the saving from a similar job we had just finished (which had DALI and Lighting management software, so easy to do.)
In a similar building type, the lighting effectively stayed on all day as the occupancy pattern exceeded the delay time.
Net energy saving - zero, net capital cost, - increased, whole life energy burden accounting for the detectors - increased. Shortening the delay time also caused premature lamp failure due to frequent switching.
Needless to say, we binned the idea at the clients request based on the evidence we provided
If it's a village hall, I guess it has defined opening and closing times (and a security system) - get the caretaker to switch on and off as required - or just fit a simple relay that opens when the security system is set (by definition, you then know the building is empty).
Failure is always an option
 26 June 2012 07:19 PM
chriso
I should have forseen the toilet humour this thread would provoke!!
I think it's probably worth doing, efficiency wise. For evening events I'm sure it won't make much difference. During the day however the hall is used by different groups for short periods and the loos don't really see a great deal of action.
I like the alarm link idea, unfortunately they don't have a security alarm. I always think places like this would benefit from a master switch, often easier to implement on new build. I guess that's along the lines of modern building management systems, still a little way off for your average village hall.
I'd like to go with just the one microwave detector, but I'm not totally convinced it will cut the mustard. It would save a lot of ugly surface trunking on the ceiling, might just have to bite the bullet and get one and try it out. I'll report back with my findings....
