Topic Title: Smallest solution for SC protection. Topic Summary: Created On: 30 May 2012 11:38 PM Status: Post and Reply |
What are the current thoughts on the smallest solution for short circuit protection on long tails, I usually use a Wylex CM160 unit, but in this case it is far too big.
I am looking for something like a fused version of the REC2s. ------------------------- Regards Martyn. Only a mediocre person is always at their best www.electrical contractors uk.com |
You could use your REC2 with a 2 way housing with a 63 A mcb or an inline wylex as they use for economy 7 of appropiate size but if you are using swa an adaptable box would have to come in play here. JUst some ideas.
I have used one of these a few months ago and I can't fault it for what it is!
http://www.tlc-direct.co.uk/Products/CGMSF100.html |
Perhaps something like one of these: http://www.meteorelectrical.co...units_switchfuses.html in a small modular enclosure? There are BS 1361 (sorry BS 88-3) versions about too.
- Andy. |
Don't forget that you have 3m to put the switch fuse in, so it could go in an adjacent cupboard
http://www.tlc-direct.co.uk/Products/CGMSF100.html Looks interesting. What are the terminals like inside? Thanks. Clive ------------------------- Clive S Carver GCGI IEng MIET |
http://www.tlc-direct.co.uk/Products/CGMSF100.html Looks interesting. What are the terminals like inside? Thanks. Clive For sub 20 quid I was very impressed with it, even though I was fighting 25mm SWA into it through an adaptable box! Double screwed terminals from memory although I could be making that up! Apparently you can fit it nicely into an external meter box. |
Cheers guys, The TLC switch fuse is still too big.
I was today thinking about just that solution Andy, I think I can fit that in to a MC enclosure for the swa and a separate REC2s for the single isolation point. Jumpinjax. Cant really use an MCB for selectivity purposes. I am on the end of a 6m swa which starts outside I'm sure I could manage to get a connection somewhere else but it would be a bit inappropriately located in this instance. ------------------------- Regards Martyn. Only a mediocre person is always at their best www.electrical contractors uk.com |
Update.
I ended up using a 3*3 wiska box with a Henley series 7 fuse carrier & 60A fuse sat directly on top. The Series 7 fuse carrier was a chore to find a supplier but I ended up Here ------------------------- Regards Martyn. Only a mediocre person is always at their best www.electrical contractors uk.com |
Meteor Electrical ended up selling me a very good product along the lines of a consumer unit switchfuse.
