Topic Title: Pressure switch for a bore hole pump Topic Summary: Created On: 29 May 2012 07:48 PM Status: Post and Reply |
Hi all,
I have been asked to connect up a single phase bore hole pump that supplies a single tap. The customer would like a pressure switch fitted so that the pump will only run when the tap is turned on - so that the pump is not running continuously. Can anyone recommend a suitable pressure switch, and is the pressure switch sufficient or do I need control gear to protect the pump from overload etc? Thanks. |
You need to be looking at a pressure vessel, pressure switch, check valves and some sort of starter also the pump would be suitable for the application.
------------------------- James |
For a single outlet would it not be easier to have an open pipe and simply use a manual switch to operate the pump when water is required?
Hi circle 143
Did one of these last year - bore hole company supplied the kit which had a lovely foreign flow switch which switched on when tap opened & off when closed - some sort of pressure differential detector. Have just had a call to nip and look at an existing farm installation which i think has same system - am going tomorrow and will try to get info for you if you can wait till tomorow evening regards steve |
Hi circle 143,
Based on my horticultural experience, a correctly sized pressure vessel, pressure switch, and pressure relief valve is a really useful way of ensuring that the max number of on/off cycles won't be exceeded for the bore hole pump. Reduced pump switching maximizes its working life - as well as reducing the number of times the darn thing has to hauled out of the ground! (Thermal, manual reset overload trip switches are usually used.) Regards E. ------------------------- ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ The meaning of life is a blank sheet; write on it wisely. ~ M.Cutler. |
Good evening,
Thank you all for your responses, it is much appreciated. The job is on hold for now - but I am definitely going for the most simple option. Thanks. |
