Topic Title: Sattelite TV
Created On: 09 July 2011 08:31 PM
GB
I have been asked to put the cables only for a sattelite TV installation with the "Sky" company fitting all the kit, the system is to have one decoder only in the living room with all other outlets showing what is on at that point, if I wire as following from a central position (loft room) will I be covered?
2no cables to living room outlet
2no cables to sattelite dish position (position agreed)
1no cable to each other outlet. (bedrooms x 4)
And do I need any interfece with the BT outlets I know you do for multi room systems but not sure about the above, I think I need one outlet in the living room for the decoder only.
Cheers
 09 July 2011 08:42 PM
typiod
2 from dish to decoder 1 back to amplifier then 1 away to each room, bt piont near decoder, your customer could then use a magic eye to control the decoder from any of the other rooms.
 09 July 2011 08:50 PM
GB
Thanks for the reply
What is the magic eye? do I need to cable for this?
 09 July 2011 09:12 PM
isj
Magic eye is a sensor which connects to the TV in other rooms to the decoder which allows channels to be changes from bedrooms etc.
Ian
Please visit my web site http://johnstoneselectricalservices.co.uk
or blog
http://johnstoneelctricalservices.blogspot.com
isj
Ian
or blog
 09 July 2011 09:24 PM
GB
Cheers > much appreciated
 09 July 2011 10:08 PM
The "magic eye" communicates over the coax cable, and also receives its dc power over the coax. You need to ensure that your aerial amplifier will supply power to its outputs and is able to pass the control signalling back to the Sky box - not all types will work in this application.
 09 July 2011 10:18 PM
Also you need to be using "rf out 2" (and make sure the volts are switched on in the menu) for the link as the other one doesn't have volts on it,
 09 July 2011 10:57 PM
Avatar for sparkiemike.
sparkiemike
 10 July 2011 05:59 AM
Avatar for dickllewellyn.
dickllewellyn
Forgive the hijack, but I have a similar question. A house we are working on in Central Winchester cannot have a satelite dish, but has Virgin on the street. Is this wired internaly the same as sky? They will be having more than one receiver, so I figured 3 cables form main receiver to dist amp in cellar, then simply one cable to each additional TV?
Regard
Richard (Dick)
www.rllewellyn.co.uk
 10 July 2011 04:23 PM
flameport
If they are having a separate Virgin box in each room, all you need is to install 3 cables - from the wherever the main Virgin cable enters the property to each room where the box will be fitted. Nothing else, just leave the cable ends loose, Virgin or their installers will do the rest.
RG6 cable usually.
 10 July 2011 05:43 PM
sparky2002
And that old chestnut.......... which type of cable round the house RG6 or CT100 or derivative. If you ask Senate for a reel of satellite cable RG6 is what you'll get if you ask for a higher spec; you're greeted with raised eyebrows at my local branch at any rate.
That's perhaps why satellite engineers are rarely seen there.
