Topic Title: Yard Lighting installation
Topic Summary: Calculation Of Design Current (Ib)
Created On: 07 November 2010 10:56 AM
12216
Morning all
I have been asked to install 4 of 400w metal halide light assys in an outside yard. without manufacturers data would the following calculation be reasonable and acceptable to calculate the design load using 0.8 as a pf. i remember back from college that this was the factor to use then but is it still ok as a rule of thumb at present.
400w x 4 = 1600w 1600w / 230 x0.8= Ib
Could this same calculation also be used for high pressure sodium and fluorescent lighting assy,s
many thanks
Regards Martin
 07 November 2010 12:05 PM
Avatar for rocknroll.
rocknroll
In the absence of manufacturers data the factor for discharge lighting is 1.8
4 x 400 x 1.8 / 230 = Ib
"Take nothing but a picture,
"Oh! The drama of it all."
 07 November 2010 12:19 PM
Avatar for dg66.
dg66
The 1.8 factor that RnR has mentioned is to account for control gear losses which result in additional current,and the possible introduction of harmonics from the control gear.
Dave(not Cockburn)
 07 November 2010 02:32 PM
12216
Many thanks to you both.
just out of curiosity when do you use the following P / V x 0.8 ( based on 230v supply)
 07 November 2010 02:50 PM
rocknroll
You cant just use it on its own, you have to use it in conjuction with data about power losses, harmonic currents and p.f.
Lets take some live data from a manufacturer;
400W lamp
20% control gear losses (in real terms this is more like 25% or 100W)
Harmonic current of 0.598A
Power factor of 0.9
If we do the calc using the recommended 1.8 factor all we need to do is,
400 x 1.8 / 230 = an Ib of 3A.
Now using the manufacturers data above,
400 + 100 (losses) / 230 x 0.9 (p.f.) = 2.4A
2.4A + 0.589A (harmonic current) = an Ib of 2.98A
How close is that then
Note that the 1.8 factor is only good for a power factor down to 0.65/0.7 after that then you need to use manufacturers data.
Edited: 07 November 2010 at 03:32 PM by rocknroll
 07 November 2010 05:44 PM
12216
400W lamp
Power factor of 0.9
Many thanks RnR for your time on this one.
Martin
12216
400W lamp
Power factor of 0.9
Martin
