Topic Title: DOL STARTER
Topic Summary: AUTO START
Created On: 14 January 2007 10:24 AM
REPTON66
Good morning everyone can someone please tell me how i wire a dol starter to perform auto start when supply is present.I have to wire a commercial central heating pump from the above and the supply is via a timer control.
Do I short the start button out.
please forgive my ignorance but I have never fitted a dol starter before and am a bit green!
Regards Andy.
 14 January 2007 10:31 AM
If the pump is operating under timed control the start button is simply replaced by the timeclock contacts
If the main electrical supply is given to you already under time control simply omit the start button contacts by means of a link
Be careful of the latter method - BS 7671 requires you to consider the risks of equipment automatically restarting following loss of voltage.
Personally, I would first determine the controls philosophy adopted and then work from there
 14 January 2007 11:35 AM
REPTON66
do the starters come complete with varied wiring configurations and links connected?
 14 January 2007 11:46 AM
rocknroll
Yes they normally do, there are normally a couple of links, one you remove for remote operation, and often one you remove if you want to fit a float switch or similar control.
If you do a search you should find some DOL wiring diagrams on the net, they can be used for many applications.
OMS is right, be careful, weigh up the risks.
"Take nothing but a picture,
"Oh! The drama of it all."
 14 January 2007 06:03 PM
REPTON66
cheers for that I found some diagrams and now understand how the control circuit works simple series circuit.Just a bit ignorent of termonology.
REMOTE and local switched and float swich.
