Topic Title: Earth Sizing for sub main
Created On: 15 August 2006 07:23 PM
deleted_13AMP
Hi, Am installing to two flats with meters in a hall cupboard,with regards to each flat I intend to install a 16mm submain as follows,there is 100amp supply, 25mm tails to 63amp switch fuse, then from here 16mm twin and earth to each flat consumer unit. Is the 10mm earth (in the t+e sufficient for the main earth or will a seperate 16mm earth need to be installed? Many thanks
 15 August 2006 07:30 PM
perspicacious
"Is the 10mm earth (in the t+e sufficient for the main earth or will a seperate 16mm earth need to be installed?"
Are you sure 16 mm2 TW/cpc has 10 mm2 cpc? Doesn't it have 6 mm2?
BOD
 15 August 2006 08:17 PM
lbelectrics
Bod you're right. 6242Y 16mm has 6mm CPC.
I remember an older standard of 16mm T&E that did have a 10mm CPC, and am sorry that it's no longer available. (Made certain bonding requirements easier to satisfy...)
Any idea what type this stuff was ? The CPC was tinned copper I think, and the live conductor insulation may have been XLPE ???
Lee
 15 August 2006 08:28 PM
DOUGIE1000
Im prob going over the top, but i would uses 3core 25mm SWA.
Dougie
Dougie
Power Plus Electrical.co.uk
 15 August 2006 11:41 PM
peteTLM
SWA all the way.
T and E is rubbish at the best of times, as a sub main, i would avoid. 6mm cpc insufficeint IMHO.
P
 15 August 2006 11:44 PM
ady1
I would run a 10mm G\Y to be on the safe side from each 63a SFU. I would also fit a main cut out switch to isolate both flats at source.
Ady
Resistance is futile.
 16 August 2006 03:35 PM
deleted_gcottingham
Dougie
Why use 25mm SWA surely 16mm would be enough with a 63A fuse?
Graham
