Topic Title: TT without a 60947/3 main switch
Topic Summary: Not seen one like that before
Created On: 13 November 2017 07:08 PM
ady1
Hi
I worked on a domestic installation where the main switch on a split board was basically replaced by a 100ma time delay RCCB.
Is this ok, as thinking about it - its still double pole whole board isolation and it doesn't trip when testing the 30ma side of the board?
Any thoughts?
Ady
Resistance is futile.
 13 November 2017 07:30 PM
dustydazzler
That's how they used to be
 13 November 2017 07:37 PM
ady1
So, not that i'm doing an EICR but if I was, I presume therefore it would warrant no code either?
Ady
 13 November 2017 08:07 PM
dustydazzler
Depends
I guess
This will probably get various conflicting answers
 13 November 2017 08:40 PM
geoffsd
Think about how you would connect a 'main' switch if there was one as well.
It would be pretty pointless, wouldn't it?
 13 November 2017 09:27 PM
Sounds good to me.
 13 November 2017 09:45 PM
I've fitted an odd one or two like that. In the days of the plastic CU and before the change to dual RCD boards, it was one of the options that Hagar among other makers recommended as a one box TT solution.
The RCD is the double pole main switch. Has the right contact gaps so long as it is marked as EN 61008 from the notes.
 13 November 2017 10:50 PM
geov
Additional protection?
 13 November 2017 11:36 PM
Alcomax
Nothing wrong with that arrangement. Nice and flexible design. You can have an rcbo if your new work requires additional protection.
 14 November 2017 08:58 AM
Ady mentioned "the 30m/a rcd side of the board" so it seems there are rcd's there.
 14 November 2017 09:16 AM
geov
Note to self - must read OP more carefully!
 14 November 2017 11:11 AM
Nothing wrong at all with a 100mA S-type front-end RCCB.
Only reason for coding I could think of would be if it was a metal CU and all the wiring on the supply side of the RCCB wasn't class II. (My personal preference would be for the 100mA to be in its own insulating enclosure before the CU.)
 15 November 2017 09:23 AM
ady1
Thankyou for the replies.
I just had not seen it before (hardly any TTs around), but at the same time I couldn't fault it.
Maybe only that it was labelled main switch and its actually RCD Main Switch.... yep, I need to get a life
Ady
