Topic Title: Shed supply
Created On: 08 November 2017 07:04 AM
NR316
Hello
I was wondering when is it appropriate to install a 2 way fuse board in a shed instead of a 20A radial (with a fused spur for lights) from the house consumer unit.
Thanks in advance
nr316
 08 November 2017 07:54 AM
dustydazzler
Depends which side of the bed I got out of
In seriousness, only if a greater demand is required in the shed.
 08 November 2017 08:38 AM
Jaymack
Depends if you may require outside sockets etc., in the future. Do you require an earth rod?
 08 November 2017 08:48 AM
Zoomup
There is nothing wrong with installing a two way consumer unit in a shed, sometimes referred to as a "garage unit". R.C.D. protection is also a wise thing. The garage unit normally contains a 30mA R.C.D. as a double pole main switch. So if you use the shed's sockets for outdoor equipment then greater protection is afforded by using a garage unit with R.C.D. But if cash is tight then the original plan can also be used. A 30mA R.C.D. at the circuit's origin in the house can be utilized to offer protection to the shed sockets.
Z.
 08 November 2017 09:29 AM
It does indeed depend on the shed, its intended use, and the likely budget.
A fused spur out the back of a kitchen socket by the back door may well do just fine for a lean to dog kennel sized effort storing 3 children's bikes and a second hand lawnmower that is the largest load ever to be used. In some more downmarket examples of such a cases I'd rather have a plan for easy isolation and decommissioning in case it blows away in a high wind, where it becomes an outdoor socket on the wall.
A small office or workshop requires a more thought out approach as there may be heaters, IT equipment giving near constant loading, machine tools, emergency lights ..... Then a 'full monty ' small CU on a distribution circuit is in order.
 08 November 2017 09:46 AM
dustydazzler
Are we talking small garden tool shed or 200sq foot garden work shop
The later might warrant more then a skinny 2.5mm cable spur of the house Rfc
I have a 2 way screwfix garage jobbie in my shed but only because I had taken it out of another job so put it back to good use.
Otherwise I would have fitted a dual patters north south just inside the shed door and put a socket at the bottom and the swi spur at the top to act as my light switch
