Topic Title: Induction hob and oven
Created On: 20 April 2017 08:31 PM
Clintrose1
Can a 10mm T+E take an induction hob of 6.4kw and a double oven 5.1kw?
 20 April 2017 08:57 PM
weirdbeard
Appendix 4 BS7671 >
:beer)
geoffsd
Yes, so can 4 sq.mm. Method C with 32A MCB.
10 sq.mm is a sub-main for a flat.
 20 April 2017 09:19 PM
I would prefer 6.00 mm.
 20 April 2017 09:27 PM
geoffsd
You old fashioned thing, you.
As above - Appendix 4.
 20 April 2017 10:00 PM
well, what size breaker is upstream of it, and what thermal insulation are you routing it through.
However unless it is extreme, almost certainly yes because Thermostatic controls conspire to keep turning ovens and cookers on and off after the first few minutes so the actual cable heating is much reduced over what you may imagine from the ratings. This is reflected in the advice alluded to above, which has many years pedigree..
 20 April 2017 10:34 PM
I work it out at 22A after diversity (presuming no socket outlet on the cooker control unit) - so at a push a 25A MCB and 2.5mm2 might suffice.
 20 April 2017 11:21 PM
Alcomax
For balance to the OP , cable routing must truly be method C to hedge your bets on <10mm. Insulation is everywhere is present build techniques. Downstairs kitchen, cable through joists and ceiling stuffed with insulation?
