Topic Title: Changing route of 11KV cable
Topic Summary: High Voltage
Created On: 11 July 2012 11:12 AM
adamtaylor
Hi
I have currrently been asked to get the ball rolling on a job that requires changing the path of a 11KV cable. The cable is a 120mm copper type PILC and is expected to be double wire armoured. It is buried in the ground and the new route is expected to go above the ground about 40 foot in the air against a solid wall. Only part of the cable is getting replaced so two pits are being dug and jointed at both ends.
Can anybody please direct me in the right route of regulations that I can look at or any other information I can read up on that may help me with this job.
Any help is much aprreciated!
Fail to prepare...Prepare to fail!
Adam
 11 July 2012 12:34 PM
ArthurHall
There is no HV regs book as such, just EAWR and good engineering practice, along with other guides and codes of practice.
The cable has to be heavy enough to do the job, and has to be installed to the makers spec's. Joints must be suitable for the old and new cable. Can the new cable sheath carry the prospective fault current? will the new cable alter the circuit impedance to the extent that the protection has to be reviewed?
Probably the most important consideration is do you have safe working practices in place for this type of job?
Are you controling ths work your self or using a suitable contractor?
 11 July 2012 12:55 PM
adamtaylor
Thanks for that information,
We are currently looking for a suitable contractor for this specific job.
Adam
 11 July 2012 01:11 PM
ArthurHall
What is the approx location of the job?
 11 July 2012 03:37 PM
adamtaylor
Sheffield
Adam
 11 July 2012 03:58 PM
ArthurHall
Try
Quartzelec
Wootton and Wootton
EDS
I have no intrest in any of these but have worked with them all in the past and know that they do this type of work.
 12 July 2012 07:22 AM
adamtaylor
Thank you very much,
Much appreciated
Adam
 12 July 2012 09:37 AM
MickeyB
I have a very good method statement for this task. send me a PM if you would like a copy.
 14 July 2012 02:12 PM
adamtaylor
Much appreciated Michael
Adam
 14 July 2012 07:31 PM
GJH
Hi Adam
I work for a company who can give you a quote for that type of works.
PM if you are interested.
 15 July 2012 07:27 AM
adamtaylor
Thank you,
But the contract as already been sorted now, just help with any regs or codes of good practice would be much appreciated now.
I will keep you in mind though for future projects
Adam
