Topic Title: "System design for energy saving street lighting and traffic in Vietnam today"
Topic Summary: on ap standa, on ap standa tot
Created On: 18 May 2013 06:44 AM
onapthanh
1. Rationale
Energy includes two types: Renewable energy and non-renewable energy. At present, our country as well as many other countries are exploiting 4 commercial energy is traditional hydropower, coal, oil - and gas atoms. In addition to hydropower as renewable energy, the remaining 3 types of non-renewable forms of energy, that is exploited to a certain level will end.
Use energy needs associated with environmental sustainability, restrictions affecting climate change. And the new trend of using energy resources avail endless, environmentally friendly and renewable energies such as solar, wind, tidal, wave, hydro, nature waste, ... At present, most people are aware of solar energy is very large, easily obtained, and is well suited to the climate in Vietnam. Vietnam is a country with an average of 1 day sun is high, about 5 hours of sunshine / day. This is a very favorable conditions for efficient use of this energy source [Link Removedon ap standa]
A public lighting system needs to meet the conditions for stability, reliability, safety and urban landscape while saving electricity is a requirement of urban areas and cities. To accomplish this goal need to adopt measures illumination-application of new technologies for energy saving street lighting and traffic in Vietnam today.
2. System Requirements
A block diagram for a lighting columns as follows:
The system will consist of building components:
- Solar 12V DC power supply [Link Removedonaprsc]
- Power adapter (charger, DC / DC, Inverter DC / AC, battery)
- Power supply (12V power supply for LED lights).
- LED lighting.
- LED controller.
- Lampposts.
The principle of the system:
- The lampposts activities independently. Each light pole will be attached a system of LED lights, one controller.
- Control the light by the potentiometer controls for the lighting circuit. For example, when it starts up, the lights began to dim, when it gets dark, the light stays permanently at full capacity ..
- Programming schedule for lighting by time of day, by day of week, holidays, timetables for outdoor lighting, ensure adequate lighting for security requirements and safety . We use these buttons to control the lighting system. For example, the default button when the light sensor detects the light does not light, turn off the light sensor detects light ...
- Solar cells to provide power to the system circuits, sensors .. battery to recharge for the night will be used to provide the LED system.
3. Theoretical Foundations
3.1. DC / AC
Purpose:
- Use solar power
- Power Supply AC 220V - 50Hz stable
Ingredients:
- Solar Cells
- The Battery
- Battery Chargers
- The converter Converter DC / DC
- The inverter DC / AC (12VDC/220VAC)
Activity:
- Solar DC power supply, the charger will be passed on Battery charger. The inverter takes the DC power input and the output is 220V 50Hz AC power.
During normal operation, the input DC voltage is supplied by solar panels. When the battery is charging systems, high voltage stage to accept the battery down and charge the battery voltage level. When the battery is fully charged, the battery charger switch to stand-by mode.
In the case of input power failure occurs, the system will take a way from the battery source. When this adapter DC / DC mode work boots. The purpose of the converter DC / DC to DC power is increased and the removal of the unwanted components in order to provide stable DC power for the inverter. The converter DC / DC will generate output voltages 440V between the poles, 220V-220V at the anode and the cathode.
Inverter DC / AC converter using a DC voltage of the output pulse voltage is approximately sinusoidal shape. The purpose of the adapter is to provide a voltage output frequency is determined by the reference signal. A sinusoidal reference signal is compared with 1 strip of symmetrical triangular wave signal resulting pulse width modulated.
Pulse input range is 1 LC filter, creating a sinusoidal voltage supply to the load. When 12V DC input is provided by solar cells due to any other reason that, the system still provides 220V AC power load stability.
 25 December 2013 06:47 AM
edwinjarvis
This is a good alternate to use renewable resources rather than the non-renewable resources so that we can save resources for the next generation.
 01 January 2014 10:42 PM
SKElectrical
Originally posted by: onapthanh
System Requirements
- Solar 12V DC power supply [on ap rsc \ onaprsc totonaprsc]
- LED lighting.
- LED controller.
- Lampposts.
3.1. DC / AC
Purpose:
- Use solar power
Ingredients:
- Solar Cells
- The Battery
- Battery Chargers
Activity:
There is so much that can go wrong here, I find it impossible to believe that such a design is sustainable, with regard to maintenance. Indeed, the cost of maintenance of complex setups is very very high.
I do a lot of work with commercial lighting; while LED lighting certainly uses less power, its drawback is the large cost of both installation and maintenance. I would like to add that LED has been sold to designers as having a long life, free from failure: this is not the case.
I sincerely hope that I am proved wrong.
