Topic Title: Zones
Topic Summary: safe ?
Created On: 13 October 2015 08:03 PM
Ampman
Evening ,
i first fixed a extension for a builder 2 weeks ago which included outside lights either side of the patio doors , i ran wiring internal & drilled out to the lights as ive always done for past 20 + years .
builder said building inspector requires these cables to be steel capped ( cos of curtain rail fixings etc ... )
the said cables are 150mm from the edges of walls so are in safe zone anyway , cables will be rcd protected ,
any body eles see a problem with this ?
i read the regs & they state that the zone extends on the reverse side of the wall but only if wall 100 mm thick or less , the walls in the extension are 300mm including cavity ,
cheers
should the capping be earthed ?
 13 October 2015 08:12 PM
perspicacious
http://www.theiet.org/forums/f...d=63107&enterthread=y
BOD
 13 October 2015 08:20 PM
Ampman
cheers Bod,
thanks ,
 13 October 2015 08:21 PM
If cables definitely are <150mm from the sides the inspector clearly isn't working to BS 7671 requirement. Steel capping is unlikely to satisfy BS 7671 for mechanical protection - nails easily piece it after all - and even if earthed it wouldn't satisfy the requirements for concentric earthed protection either (has to be conduit, trunking or certain specified cable types).
It could be that the inspection is simply making a "suggestion", probably based more on his experience than bookwork, that steel capping may well provide some protection from relatively blunt DIY masonry drill. Or perhaps he expects the walls to be wet plastered and is thinking of protection from the plasterer's trowel.
 13 October 2015 08:24 PM
I think that's just there to avoid the problem with thin walls where a cable serving an accessory in one room would also be <50mm deep from the surface of the wall of the room on the other side of the wall.
 13 October 2015 08:36 PM
aligarjon
If there is a chance they might get hit by curtain poles take them sideways to the corner then up. (presuming they come through lower of course) After all its you that will have to put it right if they get hit.
Gary
 13 October 2015 09:21 PM
mikejumper
I don't.
But the building inspector obviously sees a potential problem and has given a reason.
For a small amount of effort you can keep the inspector happy and get him / her on your side.
I'd fit the steel capping and perhaps double them up.
I wouldn't earth them.
 14 October 2015 07:27 PM
Zoro
Cable to BS8436 is useful for lighting when Safe Zones are not available, no need to cap either.
 14 October 2015 07:33 PM
Steel capping would do bugger all as far as nails, drills or screws are concerned!
