Topic Title: Be Honest. Do you twist concuctor ends before termination?
Topic Summary: Do you terminate single earth conductors without doubling over?
Created On: 11 January 2015 05:39 PM
Zoomup
https://www.youtube.com/watch?v=yx063dxU4ng
 11 January 2015 05:53 PM
peteTLM
9 minutes to put a cooker switch on. Id be bankrupt if i carried on like that.
What was he trying to achieve by trying to use CABLE SHEARS to strip the cable. Oh dear.
Who done the plastering, stevie wonder?
No i dont double up/ bend over cpc connections. However if it dosent achieve a suitable connection (1.5mm solids into a memshield 2 earth bar designed for 16mm conductors springs to mind,) then i might consider it.
Yes i twist stranded conductors otherwise they just splay out everywhere..
Amateur.
 11 January 2015 05:57 PM
potential
Yes I'd probably double up the earth.
After watching how the wires were stripped, the terminations tightened just the once and the wires shoved back into the box I would want to check everything that installer did when he left.
 11 January 2015 06:04 PM
Manxie
Slow and rough!
Also just watched the same guy install a cu.
Finished job looked like a birds nest!
He even had the balls to show his face at the end...
No shame whatsoever
 11 January 2015 06:06 PM
peteTLM
You should see the state of his other video changing a consumer unit. MCB's all leaning over, 1 rcd for the whole board, meter tails stripped with teeth by the look of it. Spaghetti.
I love to support people, and always try to be positive and give encouraging feedback to people, but this guys not a good example.
 11 January 2015 06:08 PM
spinlondon
Yes inner cores were again too long.
All very well advising not cut them too short, he should also advised to ensure none of the conductors get caught by the fixing screws.
 11 January 2015 08:54 PM
In answer to the OP, I try and at least half fill the terminal with copper, so I will double back wire ends as required to do this, and multistrand needs ferrules if its thin strand flex or twisting if its fatter stuff.
But no, not quite like that !! Still, he's left enough slack for it to be remade a few times if required.
Things need to lie comfortably, tighten, be given a wiggle to shake em down, and retighten if required (which on the large stuff is quite often.)
 11 January 2015 09:19 PM
stateit
Write to the manufacturers and ask them.
I did when I was bored one day. MK, Wylex, Scolmore, Crabtree.
MK must have had a slack day on the day I wrote in as they replied (no others did).
They said insert conductors straight, not doubled over, and not twisted.
Remember that MI override other regs. So now go back to all your installs and undo what you have done...
S George
http://www.sg-electrical.com
 11 January 2015 09:34 PM
Well I think the AM3 version has changed the manufacturers bit. It will now be required to consider the manufacturers instructions. I think! I haven't yet got the book. And not yet anyway.
Edited: 11 January 2015 at 09:41 PM by leckie
