Topic Title: when to use 3 pole or 4 pole main switch
Created On: 21 March 2013 06:49 PM
<< 1 2 Previous Last unread
 16 November 2013 09:42 PM
So, are we now agreeing that a 4 pole isolator is only required for a TT system?
 16 November 2013 10:53 PM
jcm256
With two supplies Mains or Generator, in some cases you need to fit a 4 pole change-over-isolator (or contactor) if your mains supply is TN-S, otherwise your DNO or IDNO mains supply would be changed to TN-C-S via the earth/neutral link at the generator terminal box when supplied from a three phase generator, (Island mode operation). Some of that may be superfluous there are variations, like one supplier "only" supplied by the DNO or IDNO transformer where the neutral/earth is linked at the transformer anyhow, and then a solid un- switched neutral change-over-isolator may be ok with their permission. It is interesting the comments about four pole devices deployed with UPS and generator systems. how long have you got if you use a 4 pole COS, between mains off and generator can be seamless to an extent but electronics is even faster than a micro mill second when you loose that neutral. Just being bold in expressing ones view, badly written but what could you have me retract, no need it all works somehow.
jcm
 24 June 2015 09:11 PM
leegibbins
Anyone ever considered the use of overlapping neutrals?
IET » Wiring and the regulations » when to use 3 pole or 4 pole main switch
