Topic Title: rewirable consumer unit
Topic Summary: change
Created On: 30 May 2007 10:51 PM
120409
I have been looking at a few jobs for a for a loft conversion company as they need a sparky. 1 lighting circuit, 1 ring circuit and 1 circuit for mains smokes are installed in to the loft area. There has been 6 way rewirable units in the houses and usually the fuses have been doubled up and even three circuits feed from one fuse. I have been advised them to change the consumer unit to a new 10/12 way mcb board etc. they are saying no, just put a 3/5 way supplementary unit in off of a henly block. and leave the existing unit as is due to cost. dont like the idea myself. any advise?
 30 May 2007 10:57 PM
Jez937
What categary will you grade the fire alarm / smoke alarm when you certficate it?
Not being an ass, would like to look it up and help you out, if I can?
 31 May 2007 07:21 AM
normcall
One reason why I hate working for builders - they do like to do things their way!
Norman
 31 May 2007 11:33 AM
120409
Grade D Category LD3
 31 May 2007 01:44 PM
Unless there's an switch-disonnector (isolator) before the henleys, you'd not have a single main switch for the installation - 460-01-02.
 31 May 2007 02:18 PM
120409
the tails would come from the meter to the henly block then to the main house cu with a main 2 pole isolater, and to the loft supplementary cu with a main 2 pole switch. both protected by main supply company fuse head.
 31 May 2007 03:10 PM
davebarman
Those sort of days are well behind us.
If it was my job I would be looking to put in a new split load board and take a sub-main from there to the loft.
Henley Blocks may have their place but I don't believe they should be on the main tails. (how very sixties).
How are you going to singly isolate the supply.
The builder I am sure could get the extra cost that would be involved as an "extra"
Otherwise just don't bother why keep him happy, is he going to sign the cert. I think not!
Dave
Never knock on Death's door. Ring the doorbell and run like hell, he hates that!
Edited: 31 May 2007 at 03:11 PM by davebarman
 31 May 2007 03:36 PM
rocknroll
I suppose you have to remember is the builder will have put a price in for the electrics and the less he can get you to do the more money he makes, I think its time for 'take it or leave it'.
"Take nothing but a picture,
"Oh! The drama of it all."
 31 May 2007 03:46 PM
120409
leave it
 31 May 2007 06:50 PM
Voltimax
What exactly is wrong with the practice the builder is suggesting? Have you ever read Brian Scaddans electrical installations publication? In his example of installing a 9KW kiln, he advocates that exact practice. Personally I try never to do this, but I have been advised to do it several times by the NICEIC.
This post has been Chuck Norris Approved.
Edited: 31 May 2007 at 06:51 PM by Voltimax
 31 May 2007 07:31 PM
120409
so you say you dont need an isolator before the henley
 31 May 2007 08:24 PM
Voltimax
I never said any such thing. Read my post again.
The publication I speak of is well known and I believe that Mr Scaddan is an honary member of the city & guilds and examiner.
I have pointed out that he has advocated this practice in his book. Therefore I'm asking the question, how is it that he recommends such a practice if it is wrong?
Edited: 31 May 2007 at 08:32 PM by Voltimax
 01 June 2007 05:07 PM
den1962
Going back to the first question about 6way rewirable board, having multi circuits from each fuse, don't reg 314-01-04 cover this ?.
just a thought
 01 June 2007 05:14 PM
Nope, because the definition of a circuit (see part 2) is anything "protected against overcurrent by the same protective device" - so everything connected to one fuse is therefore the same single circuit - regardless of how many cables there are. (I think you'd have to connect a circuit (e.g. each log of the same ring) to two different fuses or borrow a neutral to contravene 314-01-04).
 02 June 2007 09:19 AM
den1962
andy
it may be the way we both interpret the regs i see each cable coming out of a fuse as a final circuit.
that why it comes under installation of circuit arrangment.
having say 3 or 4 lighting circuits coming out of one fuse which wont blow because its not over load not make it right.
den
now i may be wrong
Edited: 02 June 2007 at 11:20 AM by den1962
 02 June 2007 10:36 AM
So, fitting a junction box two inches from the consumer unit improves it?
 02 June 2007 11:27 AM
den1962
no that just makes poor workmanship,as having joint boxes around a consumer unit just because there are no spare ways or fuseholders are crammed with cables.
 02 June 2007 11:45 AM
Exactly. I still agree with Andy's definition of a circuit from earlier though. What is important, and that goes for any termination, is that the number and size of conductors joined should not exceed the manufacturer's recommendations.
 02 June 2007 12:10 PM
GeoffBlackwell
Originally posted by: den1962
andy
den
now i may be wrong
Yes you are - wrong that is
We have ring circuits and radial circuits. Some countries have tree circuits - one trunk and then a number of branches.
We are discussing a circuit that consists of a number of radial runs from a CPD - so what will we call it? - A brush circuit, or may be a bush circuit, or you decide - answers on a postcard please.
Remember we can have rings with a spur from the CPD and we could of course have multiple trees from the same CPD .
The point is, as others have pointed out above, we can have anything we like provided it complies with BS 7671 and that means that it has: over current protection, shock protection etc, etc. BS 7671 wisely does not specify the precise format of the circuit (the IEE stopped doing that when the 15th edition came out).
You may call these things bad practice but I recommend that you think carefully about that - what is it that makes them bad?.
Geoff Blackwell
 02 June 2007 12:59 PM
GaryMo
Reading 460-01-02.....
It also states that where and installation is supplied from more than one source, a main switch shall be provided for each source of supply and a durable warning notice shall be permanently fixed in such a position that any person seeking to operate any of these main switches will be warned of the need to operate all such switches to achieve isolation of the installation.
Could you call 2 CCU's fed from a common henley block to be 2 sources of supply to an installation? Is so then could you get away with suitable warning notices?
IET » Wiring and the regulations » rewirable consumer unit
