Topic Title: Testing Capacitors
Topic Summary: Using an Insulation/Continuity tester
Created On: 07 May 2010 01:48 PM
Avatar for TwinBrown.
TwinBrown
Hi,
Can anyone provide details/tips on testing a run capacitor single phase, it is being used on a motor in a dishwasher and i suspect this may be the problem.
Any helpful suggestions welcome.
Kind regards.
 07 May 2010 02:08 PM
TwinBrown
Its ok guys,
Removed the capacitor from my oil fired burner which had the same rating and fitted to dishwasher motor and off it went perfectly, so as i suspected it was the run capacitor.
Now do i want heating or dishwashing facilities? think the wife will want the dishwasher sorted 1st.
Ok, im off to find a 4 uF.
 07 May 2010 04:28 PM
Avatar for potential.
potential
Substitution is usually the best test.
Doesn't have to be exactly the same value, just the same voltage (or more) and ripple.
If testing using a high voltage please remember to discharge the capacitor.
the voltage held within it can be lethal for a long period if left undischarged.
Not all meters and not all capacitors have a parallel discharge resistor and sometimes they are broken.
 07 May 2010 04:58 PM
intrinsic4225B
I would propose that the 0.5 J or so which could potentially be stored in a 4uF capacitor tested at 500V is unlikely to be lethal to a person coming into contact with it, although it might lead to secondary injury if one were to be startled by its discharge!
Ross Currie TMIET
 07 May 2010 05:26 PM
Avatar for slittle.
Reminds me of a game to play with a group of apprentices (or students).
Involves a megger, a large capacitor and a game of catch
 07 May 2010 05:39 PM
We played the same game at Poly. In the electrical lab, there was a 210v dc supply to each bench for some of the experiments, so we didn't need the megger.
 08 May 2010 02:49 AM
Avatar for ebee.
"Catch the Capacitor" the well known game for all the family.
Fun innit?
 10 May 2010 09:58 AM
As suggested above, substituting a known good capacitor for a doubtful one is a simple means of testing.
Another crude test (presuming a mains rated capacitor) is to connect it to the mains via an incandescent lamp.
If the lamp lights at full brightness, then either the capacitor is short circuit and useless, or the lamp is not drawing enough current, try a larger lamp.
If the lamp lights not all, then either the capacitor is open circuit and useless, or the lamp is too big, try a smaller one.
If with a suitable wattage lamp, the lamp lights dimly, then the capacitor is probably fine.
 10 May 2010 01:33 PM
Avatar for gkenyon.
gkenyon
But caution with the substitution method.
There is a failure mode with single-phase capacitor-run motor systems that can damage the replacement capacitor due to overvoltage.
When you've fitted the new capacitor, best to check that the voltage it's operating at is within spec, under various conditions of motor load.
The overvoltage can be caused by various things, but normally a higher-than-usual impedance somewhere in the run winding (or connections), or the supply to the motor.
Alternatively, if you have this failure mode, just wait until the capacitor goes again - might be 2 weeks, might be 2 years !
